      10-01-2012, 07:40 AM   #265
A4RingedONE8T
Drives: Turbo ///M Roadster
Originally Posted by mfanatic325 View Post
I was wondering about that as well, but just assumed that maybe because it's just a dump (possibly for sound?) that it didn't matter where or how it was dumped?
Just guessing...
You got it. The idea of the dump came up after the exhaust was already done and there were a limited amount of places it would fit without hindering ground clearance. Trevor was looking for mainly a sound change with it open which it surely does. Actually when open, it flows more than out the rear of the car, so it's reducing some back pressure as well. I didn't just stick it there, I looked at the flow path through the bends prior and tried to place it where it would get some directed flow from the bend just before it. Most ideal location no, does it work as intended, absolutely!
      10-02-2012, 02:52 PM   #266
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Those cutouts work wonderfully on turbo cars. I have one on my VR4 and with less back pressure the turbos spool up a little faster. Not to mention the sound change is fun in traffic.
This car is sick, love the detailed photos being posted up!
      10-04-2012, 01:26 PM   #267
IDLE TIME
IDLE TIME's Avatar
Drives: still searching
AWSOME
      07-26-2013, 02:52 PM   #268
switch311
switch311's Avatar
17
Drives: Lotus Exige
sorry to revive this but did it ever start? I mean a lot money and time but did it ever run?
"Why take life so serious? No one gets out alive."
      07-26-2013, 02:54 PM   #269
ZooyorQ
Drives: BMW M3
Yes. It did/does run but needs a few additional items such as a fuel cooler/etc.
849rwhp/629rwtq - 10.56@142.7 - 5.6s 60-130 on street tires on 19x10" wheels - manual 6spd
      08-02-2013, 03:11 PM   #270
A4RingedONE8T
Definitely runs! I'll allow Marcus and Trevor to release more details when they deem it time, the car is out of my hands though and doing well!
-Shawn-
      08-02-2013, 03:25 PM   #271
spazzyfry123
spazzyfry123's Avatar
4360
Drives: Here and There
Yowza. Beautiful craftsmanship, fellas.
      08-02-2013, 03:49 PM   #272
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2020 Z4 M4.0i  [5.00]
HOLY COW BAT MAN!
2013 335is E93
2018 X5 35d
BMWCCA / ZSCCA Member
      08-02-2013, 05:33 PM   #273
seank
enthusiast
seank's Avatar
48
impressive. looks like fun. Maybe if this Beedub's, he would finally be fully satisfied. He told me "I always want more power!"
      08-03-2013, 09:28 AM   #274
A4RingedONE8T
Thanks guys, here's a few more pictures I took the day she got loaded up to head back to the West coast!
      08-03-2013, 10:02 AM   #275
JCM
Drives: Z4 M
Thats INSANE! Amazing work!
      08-03-2013, 11:05 AM   #276
Beedub
Wonderful , my new fave z4m!!!
      08-03-2013, 02:59 PM   #277
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
damn. those are some healthy numbers.
      08-03-2013, 03:10 PM   #278
A4RingedONE8T
Indeed, only 16.8psi on E85, amazing what happens when you can properly control BOTH cams =)
      08-03-2013, 03:25 PM   #279
ZStig
279
I'd love to convert to E85 on my supercharged setup. Wish it didn't require a fancy new Pro-efi
      08-03-2013, 03:30 PM   #280
A4RingedONE8T
No Pro-EFI on this car ...
      08-03-2013, 03:41 PM   #281
ZStig
279
What happens if he can't find a normal gas station? Will the stock ECU adjust?
      08-04-2013, 03:41 AM   #282
Beedub
interesting??? what happened??? a thread thread back shows lengthy work to get the pro-efi in and working.... what ecu did you swap too in the end...
its good to note that pro-efi DOESNT work with these cars, something just isnt right and they refuse to correct it....
its a shame this was kept so quite on completion....
      08-04-2013, 01:50 PM   #283
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Awesome build! and Loving the plethora of pictures. That is an amazing Z4M right there!
      08-04-2013, 10:53 PM   #284
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
Are you going to do anything cosmetic to the nose? Will you leave the air cooler exposed like that?
2013 335is E93
2018 X5 35d
      08-05-2013, 07:58 AM   #285
A4RingedONE8T
Pro-EFI just won't work the way it's setup from them. It could be made to work with some DME tuning but that journey seemed endless and the full potential of the dual vanos setup was wasted. After making our way deep through some business contacts, we came up with a solution, a very costly solution, however it seemed like the proper road to take once to this point. The factory DME is no longer in the car either. Instead a full standalone (not one you've heard of), plug and play setup completely contained inside the factory DME box, tuned via USB or bluetooth connection, E85 flex fuel sensor functioning, and is running nearly 100% of the factory functions. Some tuning/software/ECU updates are still in progress on the car and will be completed in Trevor's hands but the car is driving and running nearly 100% as stock, making great use of both Vanos and making some serious low end power on a stock S54. Just be patient, a little more time and I'm sure Trevor and Marcus will have plenty of video's and coverage of this Z4M =)
Intercooler is made to be exposed. It will be getting anodized black once in the hands of Trevor, perhaps a different bumper covering it but other than that it will stay as is.
      08-07-2013, 05:00 PM   #286
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
A silly question I guess but I'm going to go ahead and ask anyway. Is that wheel horsepower?
