      12-20-2012, 10:13 AM   #155
3002 tii
3002 tii's Avatar
2286
Originally Posted by donoman View Post
It's more of a streetability and tire life issue... I'm still deciding whether I should copy your setup (17x9.5ET35+camber_plates) or just go 17x19.0ET30. I really don't want to start heavily modifying my street car ... especially since "my other car is a 911"
Check with the guys at Apex, all those wheel fitments were on stock suspension so you may be able to get away without camber plates. But if you used those fixed plates I was referring to, your tire wear wouldn't be excessive. In fact I think I may have had less than 1.8*, maybe closer to 1.5* which is totally streetable.
Follow for latest mods
      01-07-2013, 07:37 PM   #156
TAL2GK
TAL2GK's Avatar
145
Drives: 2006 Z4M Coupe, 2017 911
This is a great thread. Buying a new set of wheels is more involved than I would have guessed, especially since I'm trying to keep a stock look.
      03-25-2013, 03:06 PM   #157
lrcigar
Drives: 2003 2.5 Roadster
Hello all,
I need help deciding what tires to get.
I have 2.5i non sport with Apex arc-8, 18x8.5 et38 with Hankook ventus V12 225/40/18 up front, on the rear I have 18x9 et42 with V12's 255/35/18. When I first got them, I had a stock suspension. I recently installed a set of H&R street performance coilovers. There is no rubbing with this set up. But the tires just look too skinny for my liking. I'd like to replaced the tires with meatier looking tires to fill in the wheel well. I'm considering for the front 235/40/18 or 225/45/18. for the rear 265/35/18 or 255/40/18. Any thoughts or suggestions?
Thanks
      03-26-2013, 03:06 AM   #158
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
235/40 on 8,5 is perfect. I think 265/35 also would look good on 9". A nice meaty look.
      03-29-2013, 12:45 PM   #159
lrcigar
Thanks,
I'll give that size a try and post some pictures in a couple of weeks.
      03-29-2013, 01:58 PM   #160
3002 tii
3002 tii's Avatar
2286
Originally Posted by lrcigar View Post
Thanks,
235/40 may rub up front with 38 offset.
      03-29-2013, 09:19 PM   #161
lrcigar
Would spacers help?
      03-29-2013, 09:23 PM   #162
3002 tii
3002 tii's Avatar
2286
Would spacers help?
No, spacers if anything might worsen it. Spacers will push the wheels out, and would only be helpful if you were rubbing against the inside, ie the suspension parts.
Your issue with a 235/40 on 8.5" and 38 offset is that
1) the wheel is sticking further out than it normally would
2) the 235/40 tire is 1/3rd" TALLER than a 225/40
I think it'll rub because I once ran a style 197 (oem sport wheel off the e90 328i) and that had a 8" front and high 30 offset. I too ran a 235/40-18 and I rubbed against the outer fender liner, right by the sidemarker. So given that you're running a rim that's 0.5" wider, I would think you'd encounter the same issue.
I would stick to a 225/40-18 up front and 255/35-18 in the rear. It'll look a tiny bit stretched but nothing to be overly concerned with. If you're set on running a 235/40, adding negative camber may help.
      03-31-2013, 09:57 AM   #163
lrcigar
Thanks, I think your right, it will rub up front. I can live with the front with 225/40/18. But the rears just look too thin for me. I may just replace the rears with 265/35/18, and raise the coil overs 1/2" since they are 1/3" taller.
      04-19-2013, 01:44 AM   #164
Hocken
Drives: Z4 Cou
Hi all
Planning to get new wheels and like the wide look..
I have found following:
8,5x19 et38
10x19 et33
I believe it will work if i run 225/35 and 235/35 ?
Got the m-tech chassi... But like an additional drop.
What you think ?
      04-19-2013, 02:28 AM   #165
Hocken
Drives: Z4 Cou
I prefer to run 215/35 and 245/30...
But the 245s are a pretty expensive dimension :/
      04-27-2013, 04:41 PM   #166
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Thanks for sharing a pic of your car. I think your wheels look great. It really helps me decide on what to get. I'm now convinced to stick with the EC-7s I've been wanting to get with the stock tire sizes - 225 in front and 255 in rear. It has the stretched look I'm looking for without going to 19" wheels.
      04-29-2013, 01:13 PM   #167
lrcigar
I decided to take a chance and went ahead got 235/40 front, and 256/35 rears. Raised the coilovers 3/4" front and 1' rear. I'm very happy with the look. and no rubbing at all.
      05-03-2013, 07:16 AM   #168
Hocken
Drives: Z4 Cou
No rub...
      05-03-2013, 07:37 AM   #169
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Looks great! I wonder how much more you can lower your coilovers without rubbing.
      05-03-2013, 09:19 AM   #170
3002 tii
3002 tii's Avatar
2286
Just becareful the running isn't noticeable at first (not static) but develops over time as you drive the car, go over bumps, turn full lock, etc.
      05-04-2013, 03:35 PM   #171
lrcigar
Thanks,
I might go 1/2" lower in the future, but I like the way it looks now.
      05-04-2013, 03:38 PM   #172
lrcigar
Thanks for the heads up. I'll keep everyone posted if any thing changes.
      05-12-2013, 07:41 PM   #173
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Thanks,
Where'd you buy your wheels and tires? My run flats are getting to the point where they need replacing. I'd like to get the tires already mounted.
Can anyone else recommend a reliable place?
      05-16-2013, 03:48 PM   #174
lrcigar
I got the wheels from apex, and the tires from tire rack. I took the car to precision auto works in long island city, NY. They also had installed my coilovers, and made the final adjustments.
      05-28-2013, 10:06 PM   #175
3point0
3point0's Avatar
Drives: 2005 z4 3.0
2006 Audi S4 Avant  [0.00]
2005 BMW Z4  [5.67]
thanks for all the info everyone, really useful. With summer just around the corner,I'm starting to search for wheels as my rubber likely won't last till the fall (my 108's have some kerbing from the PO and fixing them is almost as much as a new set of wheels) So I figured I'd step up to 19s. So I'm looking into sizing them correctly etc.
Thing is, I'm not sure what different suspension geometries are around, some people talk of zhp and sport suspensions, but I'm not sure what identifies either on the car. I think I'm running stock although my car does have the sport and premium packages if that makes a difference. Is there a simple way for me to check what suspension I have ie go measure under bumper and it should be x inches high off the ground kinda thing?
Any ideas?
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector
OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips
      05-29-2013, 04:25 AM   #176
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
I'll be getting new wheels in the near future and I came across this site in my searches:
http://www.tuneruniversity.com/blog/...n-performance/
Read through parts 1 and 2 as well, but part 3 relates to width specifically. There's also a calculator he provides here that you can type in wheel and tire sizes you're thinking about and see if they'll fit.
Don't know if anyone else has ran across this site, but it's super good info!
