      02-02-2010, 08:52 PM   #1
Jaydon Fabulous
Drives: 2007 z4 3.0si coupe
Any coupe owners get their headliner done?
One of the reasons i wish i got the ///M was because of the black headliner. I'm tired of the grey. I was wondering if anyone had theirs done? If so, what material did you use? I'm thinking alcantara would look nice and be durable enough.
My big worry is having someone tear my interior apart. Is it easy to remove the pillar trim and headliner myself?
      02-02-2010, 09:40 PM   #2
fitchesbass
Drives: BMW
pillar trim should be easy - it normally pops off and is attached with slide clips of some sort. I'd check out the guys that replaced their roofs with a CF one because I'd imagine the procedure is nearly identical to a certain extent.
Plenty of people on other forums and cars replace their headliners with suede. In terms of a wanting an M for the headliner... well that's a debatable reason why! LOL
Good luck. I would def use a professional for the wrapping portion of the project. Glue stains etc never look good when an amateur does it.
911 Carrera project car
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      02-03-2010, 01:34 AM   #3
JB 007
JB 007's Avatar
Cyprus
44
Drives: Z4MC RRS MINI...
Great idea..My car is Black sapphire and she has imola interior..I want my headliner and pillars imola How can I do it??
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
      02-06-2010, 01:25 AM   #4
Jaydon Fabulous
That would look sick!!! With my research i've seen some diy's on e36's, and it looks pretty straight forward. I'm still too scared that i'll break my trim pieces while trying to pull them off. That could turn into an expensive mistake, or are the clips and trim seperate so i could just replace the clips if i accidentally break a few?
Also, make sure you find real alcantara and not 2nd tier ultrasuede. You can get lucky on ebay, but to guarantee you'll get the right stuff you'll want to go to gulffabrics.com. And if you're going to diy, use 3M hi-strength 90 spray adhesive.
      02-06-2010, 03:58 AM   #5
laidback
Drives: M's
my next mod if i decide to keep the Z
Live as if you will die tomorrow, but learn as if you will live forever." M.G
<img src=http://i251.photobucket.com/albums/gg289/l8dback/2012/ff8d7019.png border=0 alt= />
      02-06-2010, 09:22 AM   #6
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
I have all trim pieces for sale. but not the headliner.
just to let you know in case you brake something.
      02-07-2010, 12:55 PM   #7
JB 007
JB 007's Avatar
Cyprus
44
Thanks for advice.. If I do I will let you know..
      03-12-2010, 03:09 AM   #8
SlikM
SlikM's Avatar
Drives: '08 BSM/Blk M Coupe
i've been wanting an Alcantra headliner ever since I saw it in my buddys E46 M. It looks damn good and feels even better.
      03-12-2010, 06:25 PM   #9
crfine88
crfine88's Avatar
442
Drives: E86M
Does anyone know where to get real alcantra material?
      03-12-2010, 06:38 PM   #10
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Gulf Fabrics
      03-12-2010, 07:53 PM   #11
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by nmulax View Post
thanks, you've got all the connections
      03-23-2010, 03:43 AM   #12
Vondelta
Drives: 07 Alpine White/Imola Red Z4MC
Diokaef, where did you get your body pieces (front dam)? That looks mean!
      05-22-2011, 05:17 PM   #13
CJW2OO4
CJW2OO4's Avatar
to see if anyone is selling a headliner
      05-25-2011, 08:16 AM   #14
jra
Drives: 2005 z4
Any decent auto trim shop will be able to remove/dye your pillars and recover your oem headliner.
      05-25-2011, 01:03 PM   #15
MIKe86
Drives: 90 332is
The pillars just slide up, and are attached by little plastic connectors. Accidentally broke one the other day, need to replace it
      05-25-2011, 01:17 PM   #16
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I use loctyte performance adhesive, after sitting in the sun all day, it holds MUCH better than the 3m shit. found in home depot
      07-12-2023, 06:16 PM   #17
3002 tii
3002 tii's Avatar
2288
Decade bump. I left my car with a new speed shop who after completing the work, left the car outside for 1-2 days. With the scorching heat we’ve had recently, it apparently melted the glue and my headliner is now sagging, sigh.
I’ve seen write ups on how to remove the headliner but my question is there anyway to salvages (repair) the liner? Or is replacement cloth most likely required? Also does anyone know how much a good upholstery shop charge for something like this? I much prefer mechanical work than fiddling with interior pieces and clips - knowing me I just don’t have the patience.
Follow for latest mods
      07-12-2023, 07:02 PM   #18
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
It's not repairable as far as what I've been told. The fabric is glued to a thin foam and most of the time it's the foam that is crumbling away.
Not sure if you had seen this post => https://www.bimmerpost.com/forums/sh...php?p=30270846
I just had my headliner, A/B pillars done in Alcantara. The cost can vary drastically depending on the shop...so you'll have to shop around. The first shop that I got quoted was around $2k. Then someone from one of the M3 forum recommended a nearby shop that did a wonderful job for about $800! They told me that doing it in the original fabric would cost similar, so I went with the Alcantara upgrade.
      07-12-2023, 08:38 PM   #19
3002 tii
3002 tii's Avatar
2288
Did you leave the car with the shop or remove the headliner and drop it off with them?
      07-12-2023, 08:43 PM   #20
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
I left the car with them and picked it up the next day. The shop owner told me that I was the 4th or 5th coupe that they did and in fact just finished an Interlagos coupe a couple of weeks prior to doing mine.
      07-12-2023, 09:25 PM   #21
3002 tii
3002 tii's Avatar
2288
Thanks, very helpful. Wondering if I should buy a used headliner for less (with the risk it may too come apart some the road) or pay up and retrim my existing one.
      07-12-2023, 10:03 PM   #22
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
I had thought about that as well, but ultimately I just told myself just do it once and be done instead of messing around with a used one that ultimately will end up suffering the same fate since this was the time frame that the German automakers were switching to the water-base adhesive. Both of the upholstery shops that I visited said they are doing a lot of headliners from this genre, especially Caymans.
