      02-25-2023, 11:02 PM   #1
e86nut
e86nut's Avatar
22
Drives: 2007 BMW Z4 M Coupe
Help with new seat
looking to install a Sparco R100 seat in my Z4m. Does anyone know what brackets I need to do the install and if it is a simple "drag and drop" install?
Thanks
      02-28-2023, 03:22 AM   #2
Coi
Drives: 21 X3 M40i, 07 Z4MR
VAC makes brackets specially for the Z4/Z4M and they even have the option of including Sparco sliders if you don't want it to be fixed position. Definitely a pricey solution but other forum members have had good luck with them.
The seat mounting points are the same as the E46 so some brackets for those will fit but it's not guaranteed.
      03-05-2023, 09:28 AM   #3
Beedub
i went with planted brackets...
wdb4732.00
      03-07-2023, 12:17 PM   #4
bwry
Drives: BMW Z4MR
On my MRZ4 used the Brey Krause solution to direct mount onto OEM powered sliders to install Sparco EVO L
Brey Krause R-9246 Driver Seat Bottom Mount Adapter - BMW E46/E85/E86
https://www.ogracing.com/products/br...iABEgJKTfD_BwE
