06-06-2013, 02:33 PM | #23 | |
Rep 4,726
Actuator was more like $150. I've had to replace it once because it had a circuit board go bad.
06-06-2013, 03:12 PM | #24 | |
Rep 1,663
06-06-2013, 05:32 PM | #25 |
Rep 4,726
There's a cable, but all it is is a standard connector that goes to ground and +12v, so I just bought a pigtail of that connector. I don't have the PN though unfortunately.
06-06-2013, 06:05 PM | #26 |
636
Rep 3,124
I built the actuator electrical portion for under $40. Not because I had to, but because I was cheesed off that they charge so much for it.
I also took one of the caps off with the Vanos installed. Comes right off, and there's plenty of room to get the cap out. I'm still not convinced that either of these helps get the Vanos out without tilting the engine or starting at the license plate and disassembling your way to the engine. That's why I'm waiting for someone else to try it first. |
06-06-2013, 06:19 PM | #27 |
Rep 4,726
I have done it many times, the actuator makes it possible.
06-06-2013, 09:26 PM | #28 |
Rep 832
06-06-2013, 11:25 PM | #29 |
Rep 1,663
Could you go into it in some detail? I didn't really see enough clearance to even get the longer bolts on there to slide the vanos back.
All detail you can provide would be greatly appreciated!
06-06-2013, 11:59 PM | #30 |
636
Rep 3,124
I started reading Beisan's how-to just to pass some time.
Here's a bit of trivia that I found interesting. You need to fully retard both camshafts to get at the connections to the Vanos pistons. (We knew that). I tried to turn my camshaft with the solenoid block removed, and even with the cap removed, and I couldn't budge it. I wasn't willing to force the issue. I was afraid I'd bend the spindly connection between the spline and the piston. Beisan says: "If camshaft resistant to rotation rock camshaft back and forth to release seize." That sounded vaguely familiar, so I checked the BMW TIS and it corresponds to: "Alternately press toggle switch buttons 1 and 2 several times on special tool 12 6 050". That step never made sense to me. Now it does. So I guess I should have wiggled it more. I'll try that next time I'm in there. |
06-07-2013, 09:50 AM | #31 | ||
Rep 4,726
Let me make this very, very clear for the millionth time. The ONLY thing you can dissemble without re-timing the motor is the vanos unit itself. If you take the axial pistons out you lose the timing of the motor. They will pop right out if you go moving the camshafts after taking off the vanos, and you cannot get to the bolts everyone wants to check/replace without doing so. This also applies to the bolts that hold the actual cam sprocket on. The bolts everyone wants to replace are not the sprocket bolts, but the camshaft bolts, you cannot get to these without removing all the sprocket bolts and the axial pistons. The only thing that keeps the cam in time with the sprocket/crank is the axial piston which bridges load between the cam and sprocket.
06-10-2013, 03:34 PM | #32 | |
Rep 1,663
Can you think of any caveats/gotchas/special tools or anything that you had to adjust to follow the TIS?
06-10-2013, 05:07 PM | #33 |
salty cowboys fan
6155
Rep 3,402
06-11-2013, 08:20 AM | #34 | |
Rep 4,726
You will not be able to torque down the cam sprocket bolts without a straight torque wrench but that goes for the e46 as well.
06-11-2013, 01:35 PM | #35 | |
Rep 1,663
Does the note for Z4s say anything important? The TIS I have is the last one you could download which is december 2007. If it's important enough I guess I could pay the $30 single day access and print out a pdf.
06-12-2013, 12:11 AM | #36 |
636
Rep 3,124
Spacers.
I just bought them from Tischer along with the air noozle. The idea is to "pretension" the hubs so they're not too floppy, but have less friction against the sprockets than the camshafts have in the journals. Then you set the Vanos piston positions with the actuator, and jam the Vanos home against the spacers. As you do, the hubs turn CCW as the splines are driven into them, and the camshafts don't turn. When it rests against the spacers, the splines are inserted to the correct depth. Others have found, with some success, that the exhaust spline should end up just sub flush and the intake spline should be sticking out "just a little". So you could just set them thus and skip the whole business. This would allow you to torque the hub bolts without a crow's foot, since you could do it with the Vanos off. Frankly, I wish BMW would have simply defined "just sub flush" and "sticking out a little" in mm. Then you could just set it up with a depth mic and be done with it. I'm going to get a depth mic and measure mine when I eventually remove the Vanos, before disturbing the timing. I know from INPA that my intake is within a degree, and my exhaust will be after I tweak it a little. |
06-12-2013, 01:07 AM | #37 |
636
Rep 3,124
Reading the TIS for the 100th time, here's where the splines get properly set.
In an earlier post I described it as "something magic happens" because it's a little less than obvious. "Press buttons 1 and 3 on special tool 12 6 050 simultaneously. The solenoid valves are activated and the air can escape from the hydraulic pistons of the VANOS adjustment unit. Simultaneously push on VANOS adjustment unit until it rests on special tool 11 9 170" Buttons 1 and 3 are fully retarded (retracted). 11 9 170 are the spacers. At this point the hubs are free to rotate relative to the sprockets, and the camshafts remain fixed in the reference position. With the Vanos pistons fully retracted and the Vanos body resting on the spacers, the splines will be inserted into the hubs to the correct depth. One of these days I'll measure "the correct depth" with a mic, which opens up more options on how to get there. |
06-12-2013, 01:27 PM | #38 |
Rep 1,663
Very good info thanks StickMon, looks like i'll have to order even more parts to get this done.
My concern about the bolts was the two M6x60 bolts you temporarily install to align the vanos. The space is so limited i wasn't sure they could go in.
06-12-2013, 01:57 PM | #39 |
Rep 4,726
Timing is finally set when you tighten the 6 (I think) hex bolts on the sprocket. Prior to that the sprocket is not locked to the helical gear, and as such not locked to the cam.
It's important to mention that even after those spacers are used, and 2 of these bolts are tightened, timing STILL is not set, that only provides the pretenison. Immediately following this when the vanos is tight and those sprocket bolts are tightened is when the timing is set. I like to take that opportunity to check and make sure the camshafts are still in the correct location (easy for them not to be if you do anything wrong) before continuing. The pistons MUST still be in there fully retarded position as well. You can confirm that by pressing 1 and 3 while rotating the cam in opposite direction. (compressed air supply does not have enough power to actually rotate the cam, you have to do it manually or it wont budge)
