05-22-2013, 06:02 AM | #1 |
Rep 14
how does one properly drive an automatic
Hi all
I know, it seems a stupid question, please bear with me. It's my first automatic car. Simple question - while in busy traffic and having to stop every few meters, what is best ? - always leave it in D or - put it in N Which is best for my gearbox life ? I feel that the gearbox is trying to push the car while in D and braking, so this seems not healthy. Thanks, Dan |
05-22-2013, 07:00 AM | #2 |
Rep 2,782
Keep it in drive.
05-22-2013, 10:55 AM | #4 |
salty cowboys fan
6158
Rep 3,406
Automatic tranny has a part called a torque converter which is a fluid clutch. This is the part that allows you to stop while in drive with the engine running, and it's completely normal operation. Leave it in D.
05-23-2013, 09:11 PM | #5 |
instagram 997turbotom
279
Rep 7,377
Here's what you should NOT do: while driving about 20mph, switch to N, rev to 5000rpm, and then quickly switch to D
05-24-2013, 12:07 AM | #7 |
enthusiast
48
Rep 1,695
05-24-2013, 12:39 PM | #8 |
Rep 296
Overdrive is just the final drive gear, The locking torque converter then engages the locking clutch for increased economy.
Alot of trucks come with a function to turn that locking off when towing so as not to damage anything and keep up engine speed. When on the highway and you get on the gas to accelerate you can feel it unluck even though it may not downshift it will "gain" a few RPM as it disengages. Overdrive is part of drive not a seperate element. I have driven cars with a "high stall" converter that will still rotate the back tires even when stopped at a stop sign, cars with rear drum brakes. the brakes keep the transmission from turning when stopped so there is nothing happening/no moving parts at that point. You remain stopped because the energy being transfered by the fluid in the torque converter is less that the force of the breakes holding the car still.
05-24-2013, 01:30 PM | #9 |
Rep 1,663
Really? This is not that kind of forum. How about keeping it constructive.
I don't have the faintest idea of how anything about an automatic works and thought it was a reasonable question. There's always stuff to learn and there's always room for improvement. For example you shouldn't keep your hand on the shifter in a manual, only touch the shifter when you are changing gears.
05-24-2013, 02:09 PM | #10 |
Rep 507
Sorry but when someone is asking how to drive an automatic I lol a bit inside. If it was an SMG then it would be a different story.
SOLD: 2008 M Coupe
05-25-2013, 09:18 AM | #11 |
Rep 2,782
This is true. In older cars at least, resting your hand on the shifter would cause premature wear in the syncros. You should also switch gears by cupping your hand over the top of the shifter.
05-25-2013, 10:16 AM | #12 |
Rep 100
Drives: 2006 Z4 3.0si
Wow that's helpful... what you don't realize that here in the US most cars are autotragics. Elsewhere most are manuals... this is no different than an American not knowing how to drive a stick, most do not. I haven't met anyone in SA that doesn't drive a stick or was taught to drive in one.
I did have a customer who put their car in Manual mode and drive around w/o shifting. They called to complain of the elevated noises from the car on the freeway. I had them come in from Pleasanton to Sacramento. My tech drove the car and said nothing was wrong so I had him go with the customer. She got in, pulled the paddle shifter, driving off never touching it again. Needless to say it stayed in 2nd gear....
