      08-15-2016, 04:13 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
N52 Crank and cam teeth
Can anyone confirm the following:
Crankshaft 60 teeth with two missing per rev (60-2)
Intake and Exhaust 6 teeth or is this simply 1 pulse per cam rev?
Also, can anyone point me to a MSV70 explanation document that outlines crank and cam signals and relationship? Seems to be one for the S54 engine ( http://www.unofficialbmw.com/images/...lectronic2.pdf ) but I cannot find anything on the N52.
Otherwise, if these engines are similar in signals and ECU control, then I can go off the S54.
      08-17-2016, 02:46 PM   #2
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
What are you trying to do?
Try pinging hassmachine he seems to have done an enormous amount of research on the msv70. He "lurks" in the E90 forums.
