      08-04-2016, 01:33 PM   #1
rocky79
rocky79's Avatar
Drives: 2007 Z4 Coupe 3.0SI
Z4 starter replacement & intake cleaning
Hello,
I am in the process of replacing my starter so I had to remove the intake manifold to get to it.
My question is what else I should replace while the intake is out. Intake rubber seals? any thing else?
Thank you in advance.
Do it yourself Illustrative site.
http://diyrabbit.com/
      08-05-2016, 09:15 PM   #2
onthe3rdday
Drives: 07 Z4C
You should have seals for intake and the throttle body. If less than 80k on the vehicle, I don't even bother replacing them. They seal quite well.
      08-11-2016, 03:10 PM   #3
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Don't the mileage on the car. I would replace things you can see with intake manifold out. Usually heater hoses and PCV.
