08-15-2012, 07:49 PM | #1 |
Rep 11
Is it safe to drive? Serious problem with vibrations at speed...
Hi all, wish I could be making my first post under better circumstances , I need help from a z4 guru...
Here's my problem - My 2003 3.0i (daily driver, 93k on the clock) is experiencing some bizarre vibrations and noises this past week. It feels as though they are coming from under the car and I can feel it in my seat and slightly through the wheel. The vibration is very very subtle until 20-30+ mph and below that all I can hear is a faint noise. The noise sounds like wub wub wub... or whir whir whir... depending on speed and gets louder until 40-45mph. Its easily heard but not very loud. Above 45-50mph the vibration is hard to notice and the sound gets drowned by road noise. What I've checked already -
Problems I know of with the car -
Any ideas guys? I am at a complete loss, I've worked on my own vehicles for years and none of the obvious answers seem to be the culprit. Unless I'm overlooking something obvious? Do you think the car is safe to drive? I was supposed to attend an event this weekend and was looking at a roughly 300 mile round-trip drive which seems extremely risky right now... |
08-15-2012, 08:20 PM | #2 |
Retired Paratrooper
Rep 146
I would look at the driveshaft Ujoints, CV joints and check the pinion bearing on the diff first. If everything's right and tight there, I'd drain the diff and look for signs of a bearing going bad inside the diff.
I won't tell you if it's safe to drive or not. She's already talking too you, it's a matter of if you want to take on the risk. I always follow and plan for Murpheys law. Nothing ever breaks at a convenient time, safe place or close to home. |
08-15-2012, 08:23 PM | #3 |
Rep 2,138
Drives: Me
Have you checked the rubber 'guibo' on the drive shaft?
Number 1: http://www.realoem.com/bmw/showparts...93&hg=26&fg=10 |
08-15-2012, 10:23 PM | #4 |
enthusiast
48
Rep 1,695
So, did you check the diff fluid? Its pretty easy to check. There are too many things that it could be with the information given.
It could be harmless to drive or damaging. It just depends what it is. Last edited by seank; 08-15-2012 at 10:28 PM.. |
08-17-2012, 12:06 AM | #5 | |
Retired Paratrooper
Rep 146
Interesting drive shaft setup. I didn't know these cars had a 2 piece driveshaft. Learn something new every day. Something that's not common on RWD domestics (where most of my experience as a mechanic is) unless it's a longer wheelbase like a pickup or van. Definatly take a look at center mount and bearing... 8 & 9 What you are describing is about exactly what my 04 Dodge crew cab dually was doing when my carrier bearing went out at 200k because of a siezed U-joint. Vibration was mostly felt on initial accleration but not braking and smoothed out with speed. It had me baffled for a while as I looked at everything but overlooked that carrier. |
