      08-14-2012, 09:44 PM   #23
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
I switched to Redline after break in and have never looked back.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      08-14-2012, 10:12 PM   #24
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Originally Posted by kennyfrc View Post
I have also read/heard that some race teams running S54 powered M3 swear by Redline. Funny thing is that some BMW owners seem to hate Redline products. I have had nothing short of stellar results with them in cars that have seen track/street use.
MTL makes a great difference in the ZF tranny, at least in my climate anyway. Interesting points on the additive; I now have something to occupy my research time.
      08-14-2012, 11:29 PM   #25
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Yeap Yeap.... I've been using Red Line in my Trans and Diff... for close to 4000 mile.
Made shifting a bit smoother... I might feed the S54 some Red Line as well on my next oil change.
      08-15-2012, 12:57 PM   #26
skim
Drives: 07 Z4MC
how about RP (royal purple)? i've been using royal purple on LSD and tranny
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born
      08-15-2012, 01:03 PM   #27
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Some members here said that it is a little too thin and it brakes down faster.
Unless you are planning to change those fluid every 20k or so, then you MIGHT be ok.
      08-20-2012, 05:41 PM   #28
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
The basic summary is that if you drive your car for the looks, other oils are good. If you drive your car hard, you need Castrol TWS 10W60.
Read the E46 section oil thread. Lots of very good information from Castrol engineers who were present for the development and other BMW insiders:
http://www.m3forum.net/m3forum/showthread.php?t=295656
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      08-20-2012, 09:25 PM   #29
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
^ snap...that just brought me back to square one
And I was so ready to switch over too. I'm so confused now! There is no God!
      08-20-2012, 10:19 PM   #30
G80indy
Save the Manuals
G80indy's Avatar
EC fluids upgrades and dyno tests
This makes me feel better about Redline in the M-R
I use the 0W-40 LubroMoly in my 330i and it runs flawlessly.
The TWS dynasty is over.
2023 G80 6MT, CCBs
      08-21-2012, 09:57 AM   #31
TheSt|G
TheSt|G's Avatar
I just can't imagine why on a $50,000 car one would want to risk skimping on a few bucks.
      08-21-2012, 10:54 AM   #32
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
It's not about saving a few bucks.
It's about evaluating all options to find one that reduces rod bearing wear. I could care less whether or not I save a few bucks or even pay more. I want the lowest wear numbers on UOA so I'm not swapping rod bearings at 60K.
If TWS is the holy grail of 10W-60 oil it should return the lowest wear numbers and I plan to let UOA be the judge. In my mind the biggest risk in just assuming TWS is best.
Daily: 2010 Tacoma Double Cab
      08-21-2012, 01:02 PM   #33
mfanatic325
///M-fanatic
Taiwan
193
This is true.....if there's a superior blend, I'd want to spring for it. If it happens to be cheaper than TWS, then BOOYA!
I don't discount Castrol/BMW M's partnership on creating the TWS blend, but I have a tough time believing that they update the blend throughout the years to keep up-to-date with available improvements. Whereas on the other hand, these other 10w60 options/blends came out just recently, so I'd think the R&D is recent and could benefit our motors?
      08-21-2012, 07:45 PM   #34
TheSt|G
TheSt|G's Avatar
If you read through the thread I linked, you would see that TWS 10W60 has actually been a continual project with constant updates from Castrol for BMW. It wasn't a fire and forget project for the S54, it has evolved into a bespoke project for high revving M engines.
Especially relavent post:
http://www.m3forum.net/m3forum/showp...40&postcount=2
      08-21-2012, 08:34 PM   #35
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Newer specs and upgraded formulas--"improvements"--are not always improvements. Example: as oil specs have changed, the amount of zinc and phosphorus have been reduced due to their impact on the cats, and due to the EPA requirements on cat lifespan. (These are important anti-wear additives that may be of concern for an engine that uses solid lifters like the S54.)
As the levels of anti-wear metals have been reduced, engines have gone the route of hydraulic, not solid, lifter design due to wear concerns. (The S54 uses solid, not hydraulic, lifters.) Other changes have been made as well, but the point is that engines have been designed to account for these "improved" oil specs.
The S65 is a high-revving engine like the S54, but piston speed is lower than that of the S54, and of course the S65 uses hydraulic lifters. They share high-revving characteristics, but I would not conclude that they have the same lubrication needs.
My point is that an oil that was originally designed for one type of engine may not have "improved" relative to that older engine when reformulated or modified to meet the needs of newer cars and emission regulations. Is that the case here? I do not know. However, it's something I'm reading more about, and it may be something others want to consider as well.
      08-21-2012, 08:44 PM   #36
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
heck I can furnish you with detailed documentation tha make Royal Purple shound like the greatest oil ever made, strange like the Castrol part above, the Royal Purple info was furnished by,.......... come on ........ wait for it.......... ROYAL PURPLE!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      08-21-2012, 09:17 PM   #37
TheSt|G
TheSt|G's Avatar
IIRC, the S65 uses a hybrid solid/hydraulic lifter?
      08-21-2012, 09:21 PM   #38
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Agree, spherical bucket type is what I remember reading back in '08
      08-23-2012, 07:26 AM   #39
G80indy
Save the Manuals
G80indy's Avatar
Originally Posted by Shipkiller
I have made an excel spreadsheet that has all the major 10W60 brands and their parameters. I did a lot of internet researching trying to get his data so I could put it in one place. Some of the numbers were very hard to find and I had to search through many documents. But some of the numbers I was looking for just don't exist in the public domain. Hence the empty blocks.
See the attachment.
Edit: This is now an old file. Updated versions are on the website: http://www.shipkiller.com/Z4M_Specific_Oil_Page.html
Thanks and great data by the way!
Wow!
I do recall doing a numbers comparo some time ago between RL and TWS.
As I recall and seen here again the RL numbers look really good!
2023 G80 6MT, CCBs
      08-23-2012, 07:29 AM   #40
G80indy
Save the Manuals
G80indy's Avatar
Agree, spherical bucket type is what I remember reading back in '08[/QUOTE]
You mean cylindrical or bucket type?
Is it similar to what's in the M54?
2023 G80 6MT, CCBs
      08-23-2012, 10:54 AM   #41
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Is it similar to what's in the M54?[/QUOTE]
Let me hunt the article, I believe they were bucket.
m3forum.net quoted this from a tech article:
'Hydraulic BucketTappet
The weight-optimized valves with a 5 mm shaft diameter and the spherical bucket tappets with hydraulic valve clearance adjustment are also used.
These bucket tappets with a cylindrical camshaft contact surface and rotational lock allow a high level of convexity. This results in effective valve lift characteristics with the smallest possible tappet diameter and hence tappet mass (ideal for high engine speeds).'
