06-27-2012, 10:18 AM | #1 |
Rep 16
Any help greatly appreciated...
I have a 2008 Z4MC with approximately 38K miles. Sunday morning, started her and had a very strange rough, rumbling idle. Shortly thereafter, yellow "service engine soon" light appears. I drove for a very short distance around the neighborhood and marked decrease of power, engine obviously not running correctly. Of course, I am taking it to the service department this Saturday, but prior to that time, does anybody have any idea what this might be?? Forgive my ignorance as I certainly not a mechanic, but I certainly would appreciate any knowledge of what this problem might be!
06-27-2012, 12:33 PM | #3 |
Rep 1,107
With coil packs, are there any that last longer than roughly 30-40k? I've got one in the car as a safety spare, but I'm thinking for roughly $200 in parts, why not just do them all as preventative maintenance.
Thoughts? |
06-27-2012, 12:42 PM | #4 |
Rep 556
Drives: 2003 ESS TS1 Z4
Most all last a very long time 60-90k+ but sometimes there is just a bad one. Take it to autozone or orielly's or any auto place so they can scan it and they'll be able to tell you what the code is. Tell em you have a check engine light on.
It will give you a better idea when you get it to the shop.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
06-27-2012, 03:18 PM | #5 |
Rep 16
Thank you gentlemen for the responses; I read more about a failed coilpack and the description I read about a car's behavior once this occurs is exactly what the moupe is doing! Thanks again and I appreciate your help! With the next question I will sound ignorant as hell, but is it safe to drive to the dealership approximately 15 miles at a very low speed with low RPMs?
06-27-2012, 04:35 PM | #6 |
Rep 704
Drives: '08 MC
i dont know if its safe or not, but for that reason alone i'd get out my roadside assistance card just to be safe and get a flatbed out to the house.
06-27-2012, 04:51 PM | #7 |
Rep 4,531
I blew a coil at 25k miles. It happens.
You're running on 5 cylinders, which explains the rough idle and decrease of power (limp mode). Easy swap-out and you'll be fine. Nothing to be concerned about. |
06-27-2012, 05:02 PM | #8 |
Rep 12,565
I used to have an extra set of coilpacks in the trunk of my 1.8T so I can just change on spot if necessary lol.
06-27-2012, 05:09 PM | #9 |
Rep 556
YOu can limp it to the dealer if you want to, I'd just get a flat bed tow there, its easier honestly. If you were close I'd say drive it but that's a little bit far. Your insurance should cover towing upto x amount of miles usually.
Or you can buy a coil pack, unplug your battery ((-) Negative terminal) for 30 minutes while you work on it. There is a DIY on here some where. Stupid easy!
06-27-2012, 05:10 PM | #10 |
Rep 556
Hahaha oh ya, mine would only last 15k, went through 3 before selling it, stupid MKiv!
06-27-2012, 05:19 PM | #11 | |
Rep 12,565
Man I should sell my daily and look for a nice 20th anniversary GTI. /thread jack |
06-27-2012, 07:40 PM | #13 |
Rep 556
Details?
06-27-2012, 10:14 PM | #14 |
Rep 2,782
He's correct - the damage is the result of too much unburned fuel in the mix.
My vote is for BMW Assist or towing if it's free. I would replace the ignition coil at home if you can't swing free towing. Only drive to the dealer as a last resort. Pull the codes if you're able. A failed coil will result in a "misfire cylinder _" code, P030X. Without pulling the codes you won't know which coil to replace. Lastly, even if you do have the misfire code, it may not be a failed coilpack that caused it. In my experience, a failing spark plug will cause a one-time misfire resulting in a hard SES light. A failed coilpack (usually) causes a continuous misfire. This isn't always the case, but according to your description it sounds like you have a failed ignition coil. On the 1.8T Audi/VW engine- I lived out every gearhead male's adult film fantasy when I replaced a coil on a damsel in distress' VW Bug. I pulled the code, talked to the guys at Autozone, saved the girl hundreds of dollars at the stealership, and did one of the only basic maintenance items I knew how to do at the time... replace the plug and reset a check engine light. One thing led to another...
06-27-2012, 10:28 PM | #15 |
Rep 4,128
Drives: M235i & G30 540i
I agree its a cylinder misfire and one of the coils needs to change. But the only way to know is to put it up on the computer. Pretty common with our cars and 3 series after a certain mileage they all start to go one by one. But sometimes only one can go so don't change all 6 unless another goes sometime soon. Where ever you take it to get it changed they might tell you to change all 6 but might be a waste cause the others might have nothing to do with that one going. It's not terribly dangerous to drive with 5 cylinders, in the older cars it would be more a problem but with our cars BMW shut off things that would cause a problem so 15 miles wont hurt at all. No need to call AAA or a towing company. One of mine just went out last week and my sister's own went out a few months ago. A BMW certified tech will tell you the same thing. No big deal just change it out, mine cost $164 with parts and labor.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
06-27-2012, 11:08 PM | #16 |
Skull Squadron Leader
304
Rep 2,031
I have a spare pack in my trunk just for this situation
06-28-2012, 05:50 PM | #18 |
Rep 400
You don't even need a code reader. Just disconnect the electrical lead to one coil at a time with the engine idling. When there is no change in idle you found the failed coil. Replace it and see if it runs smoother. Then go to Autozone or someplace and have them clear your check engine light and see if it stays out.
06-28-2012, 08:35 PM | #19 |
Rep 2,782
^this would work
06-29-2012, 10:54 AM | #20 | |
Rep 784
Drives: 2011.5 E90 M3
06-29-2012, 12:25 PM | #21 |
Rep 16
Hello everyone, Thanks again to all for the responses! To be safe, Roadside asst will flatbed my baby to the dealership tomorrow. Even if the repair is stupid easy, it likely will be to much for my simple mind!! Thanks again all and enjoy the weekend...
06-29-2012, 12:49 PM | #22 | |
DHS
200
Rep 4,005
Drives: 2023 M4, 2020 Land Rover
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
