      06-22-2012, 10:34 AM   #23
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
Originally Posted by bignosejim View Post
24,009 miles. The engine ran strong before the valve adjustment and is running strong...
That is after I connected the oxygen sensor cables correctly. Before that it was idling fine but hesitated a lot. I only made it around the block before pulling into my garage. I checked each coil quickly and no problems, then switched the O2 sensor wires. I thought that they would only go on one way. Turns out you can get them mixed up.
What gaskets/O-rings did you replace besides the valve cover?
Daily: 2010 Tacoma Double Cab
      06-22-2012, 12:48 PM   #24
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
I just replaced the spark plug gaskets, oil drain plug washers and the vanos pressure limiting valve filter and o-rings (parts 4,5 and 6). I left the vanos sealing plate (part 7) alone and undisturbed.
http://www.realoem.com/bmw/showparts...=11&fg=15&hl=7
      06-22-2012, 02:53 PM   #25
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Turner Motorsports used to sell a complete kit. I haven't checked their site lately, but it was a nice all-in-one package, it even had the copper washers.
      06-22-2012, 03:15 PM   #26
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
I say we get a few cars together in the tri-state area and do a Valve adjust gang bang if you will
      06-25-2012, 11:09 PM   #27
aerobod
Car Geek
aerobod's Avatar
3621
Drives: Caterham R500, M2-G87, Macan S
Just did the valve clearances at 72,000km this past weekend. Intake valves 1, 5, 7, 8, 9 & 11 all required 0.04mm thicker shims. Exhaust valves 1, 6 & 12 all required 0.04mm thinner shims.
Overall, a mega maintenance weekend with an extensive replacement set:
Engine oil & filter
Transmission oil (Pentosin MTF2)
Differential oil (Castrol SAF-XJ)
Valve adjustment
Air filter
Cabin filter
Other inspection II 'inspections'
Engine coolant
Vanos filter & 'o' rings
Spark plugs
Alternator & air conditioning belts
Engine mount bolts torque check
Front & rear brake rotors & pads
Parking brake springs
Stainless steel brake lines & brake bleed with ATE typ 200
CDV delete & clutch bleed
The car now feels stronger and smoother than ever before!
      06-26-2012, 09:09 AM   #28
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Engine oil & filter
Valve adjustment
Air filter
Cabin filter
Engine coolant
Spark plugs
That is quite a few tight exhaust valves, valve stretch or seat recession I guess.
      06-26-2012, 10:31 AM   #29
Pheonix
2007 BMW/Z4MC  [0.00]
Very interesting! Maybe he adjusted the intakes' to the lower end and the exhausts' to the higher end?
      06-26-2012, 11:38 AM   #30
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Could be, sure. I had one, and it wasn't that tight, so I landed it in the middle. Some you can't land in the middle, but I usually go more towards loose than tight, especially for cylinders 5 and 6.
      06-26-2012, 09:59 PM   #31
aerobod
Car Geek
aerobod's Avatar
3621
This is the before and after picture, each adjusted to be as far away from the spec limits as i could:
Intake
1- 0.23->0.19
2- 0.19
3- 0.22
4- 0.22
5- 0.23->0.19
6- 0.22
7- 0.23->0.19
8- 0.23->0.19
9- 0.23->0.19
10- 0.20
11- 0.23->0.19
12- 0.21
Exhaust
1- 0.26->0.30
2- 0.29
3- 0.30
4- 0.29
5- 0.29
6- 0.28->0.31
7- 0.31
8- 0.30
9- 0.29
10- 0.29
11- 0.29
12- 0.28->0.32
Only one valve was out of spec (exhaust valve 1).
I may have just had most of the intake valves adjust to the top of the limit and the exhaust valves adjusted to the bottom of the limit by the dealer at Inspection I, but the engine is somewhat smoother and slightly quieter now.
      06-27-2012, 09:01 AM   #32
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Intake
1- 0.23->0.19
2- 0.19
3- 0.22
4- 0.22
5- 0.23->0.19
6- 0.22
7- 0.23->0.19
8- 0.23->0.19
9- 0.23->0.19
10- 0.20
11- 0.23->0.19
12- 0.21
Exhaust
1- 0.26->0.30
2- 0.29
3- 0.30
4- 0.29
5- 0.29
6- 0.28->0.31
7- 0.31
8- 0.30
9- 0.29
10- 0.29
11- 0.29
12- 0.28->0.32
Those specs look really good! Exhaust valve 1 was an easy fix at .04mm increment too, put it right in the middle.
      06-28-2012, 09:44 PM   #33
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Ok people, I already ordered and received my shims and all the things I'm going to need.http://www.ecstuning.com/BMW-Z4-M_Ro...cal/ES1893858/
I'm also following the videos below part 1 & 2. for reference and that because the dealer wants $1200 plus tax
http://www.youtube.com/watch?feature...v=SoYVubj9y5U#!
      06-29-2012, 12:52 PM   #34
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
Not a tough job just time consuming because you need to methodical and careful.
Once you have done it once you realize dealer cost is not expensive, in most cases its just plain gouging.
Good luck
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      08-19-2012, 02:17 PM   #35
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
For those of you who have DIY the valve job,
How are you rotating the engine over?
Wrench on the cam?
Special tool on the crank?
      08-19-2012, 03:50 PM   #36
aerobod
Car Geek
aerobod's Avatar
3621
Wrench on the cam?
32mm socket on the end of the crank. Don't use anything to just turn one cam, you can cause damage to the chain, chain tensioner or cam itself.
      08-19-2012, 04:33 PM   #37
bignosejim
bignosejim's Avatar
I just put my car in 4th gear and pushed it forward to rotate the cams. When I ran out of garage space, put it in neutral and walked it back. You only need to move the car a few inches to get to the next cam position.
      08-19-2012, 10:36 PM   #38
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2020 Z4 M4.0i  [5.00]
^We tried that for about two seconds, (but then we had it 1st not 4th) the wrench meothod while a pain in the wrist was the better way to do it. Just have to reach down, put the socket on first then the wrench on the socket.
2013 335is E93
2018 X5 35d
BMWCCA / ZSCCA Member
      08-20-2012, 11:42 AM   #39
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
+1, I have a short garage too, made for a long(er) day, but works really well.
