      12-12-2017, 06:16 PM   #1
suprtran
suprtran's Avatar
111
Drives: BMWs
Genuine BMW CSL/Euro Z4M Headers - BRAND NEW
Sold!
      12-12-2017, 06:58 PM   #2
Jsinghzzzz
Jsinghzzzz's Avatar
Drives: Black Z4M Coupe
Sent you a pm.
      12-14-2017, 06:00 AM   #3
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Great set of pipes, I have the same.. just Lovely..
      12-14-2017, 10:36 AM   #4
kav
Drives: Z4M
I have these too and they are amazing. The sounds is so much better.
      12-14-2017, 12:39 PM   #5
Z4man610
Drives: Z4 coupe 3.0
You exceeded your storage space allowance. Trying to PM you.
Thanks.
      12-14-2017, 12:56 PM   #6
suprtran
suprtran's Avatar
111
Drives: BMWs
Inbox cleared. Thanks.
      12-14-2017, 12:59 PM   #7
SDCoupe
SDCoupe's Avatar
78
Drives: M Coupe
These are direct bolt ons, with no modification in tune or otherwise? Correct?
      12-14-2017, 01:35 PM   #8
RossBMWZseries
Maaaaan these things are pretty! Is there a big difference (in power) between the European headers to the European CSL headers?
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      12-14-2017, 03:50 PM   #9
suprtran
suprtran's Avatar
111
Drives: BMWs
Correct, direct bolt-on. Tune not required but would be recommended to optimize the free-flow nature of these catless headers.
I have no experience so I can't answer.
      12-19-2017, 11:12 AM   #10
batmobile318is
Drives: 2007 Z4MC (BSM/BLK)
I have read some modification is needed to bolt these up. You either need to retap the manifolds for the 02s and other connections, or you need to extend the wires. Could you enlighten me on this? Is it truly direct bolt on with no issues or is there something that has to be modded?
      12-19-2017, 02:58 PM   #11
SDCoupe
SDCoupe's Avatar
78
Drives: M Coupe
From what I understand, you will need to move the after cat O2 sensor to behind the secondary cats. The euro secondary cats have a port for this location. US does not. So you will need to weld a port in your existing secondary cats or purchase a DKF or euro (rare) secondary pipe with cats. However, there is some issue with passing smog in some states with this set up as a check engine light could be thrown with the DKF pipes. I think the euro version does not throw a CEL. You will also need a tune to get the performance out which is about 30hp. You may also be able to suppress the CEL through a tune. But after all this, I understand the sound is amazing.
Arsonism158.00
      12-19-2017, 03:09 PM   #12
suprtran
suprtran's Avatar
111
Drives: BMWs
This thread is a great resource for information pertaining to Euro/CSL vs US headers: http://www.zpost.com/forums/showthread.php?t=882703
David701567.00
      12-20-2017, 02:54 PM   #13
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
When I swapped to euro headers, I utilized a modified US OEM section 1 pipe with the o2 sensors and EGT sensor relocated. This essentially mimics the euro z4m cats, which if you can find a set are stupid expensive since they are rare. Just in case I wanted to swap back to the original exhaust, I obtained a second set of US-spec section one cats and had the o2 bungs rewelded for a total cost of $300 to me. A quick search will result a few diy's on how to do this.
Going this route keeps all o2 sensors and doesn't create a CEL. FWIW I am in Illinois and have the Epic Tune as well, and I passed emissions last month without reverting back to the OEM tune
As far as the o2 and EGT wires are concerned, you don't need to extend them, there is just enough length in the OEM wires. I had no issues by undoing the sensors from the wiring looms and rerouting them under the car.
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
86Zed932.00
Arsonism158.00
      12-20-2017, 04:55 PM   #14
RossBMWZseries
^ he's right. I found just enough length on the O2's and EGT. You kinda just have to run them down a certain path to get to the pipe.
      03-13-2018, 05:39 PM   #15
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
PM Sent
      03-13-2018, 09:53 PM   #16
Happyvirus
Drives: Z4MC - Monaco Blue
they look so beautiful
      03-18-2018, 03:13 PM   #17
Beedub
imo no aftermarket item can better these..... wonderful stock pieces.
      04-19-2018, 06:18 PM   #18
Happyvirus
Damn they are so pretty. I’m just waiting on something and if it goes well I’m gonna get in on this. Hopefully(for me) this lasts here
      09-18-2018, 12:26 PM   #19
suprtran
suprtran's Avatar
111
Drives: BMWs
Bump up.
      10-23-2018, 12:14 AM   #20
rueyme
Drives: red z4
are these still for sale? do you know what the labor hours it will take to install these?
      10-23-2018, 01:18 AM   #21
Jsinghzzzz
Jsinghzzzz's Avatar
Shops in the bay have quoted me 5 to 10 hours for install so install quotes have ranged from $600 - $1200. Some shops have flat out refused because a header swap is technically only meant to be used for off-road(I.e. track).
Best bet may to be find an enthusiast to help with the install in a driveway.
I haven't had a chance to get my headers installed yet either otherwise I would have been able to give you a better/more specific recommendation for a header install in the bay area.
      10-23-2018, 08:21 AM   #22
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
I did mine with a few other things (notably Rod Bearings) and was only charged 2 hours. May want to consider combining it with some other items to save a little.
