10-20-2010, 08:50 AM | #1 |
code monkey
Rep 74
I believe I also have a camshaft bolt issue
At least, I hope I have a camshaft bolt issue as opposed to the alternative.
My car has been making noise lately at low RPMs, like a rattle, between 1k and 2.5k RPM. Last night the SES light came on. I took it to the dealer this morning, mentioned the noise again. The tech pointed out that the rattle was coming from the VANOS unit. Said it was either the camshaft bolts backing out, which he has seen on 3 other cars, or the VANOS unit was failing. Based on the price of a new VANOS unit (over $3k), I'm really hoping it's just the bolts. I should know later today after the car cools down and they can disassemble. If anybody is debating getting an extended warranty, do it. I'm already $2k out of pocket from my throttle actuator replacement and cracked belt replacement. This will add on another $1k to $4k depending on how things go. |
10-20-2010, 08:52 AM | #2 |
Rep 1,135
uhhhh..... im sorry =/ shouldnt you still have some warranty left? or has your 4 year inservice date already expired??? and wait, the tech has seen other cases of e86/e85 issues? or s54 issues?
irregardless, i wish you good luck ! edit, this video sums up the sound, yes? |
10-20-2010, 08:54 AM | #3 | |
Rep 4,726
At least this tech sounds like he knows what he's doing. Find out from him what the SES light code was, if stuff goes south tow your car to me (ORL) I'll fix it for cheaper then the dealer. lol.
10-20-2010, 09:05 AM | #4 |
code monkey
Rep 74
My warranty ended mid-May this year, and not long after is when things started to go wrong.
I forgot to ask about the code while I was there - just emailed my service advisor to ask what it was. When I drove to the dealer this morning the light was off and it was no longer in limp mode. Reeves (my dealer) has been pretty good thus far, but now that repair costs are adding up, I've been looking for a good indie shop in the area. I've had two friends recommend Cars and Concepts in Tampa, and I've emailed them to see what they would quote if it ends up being a VANOS unit replacement. They told me they have a used unit off an S54 that threw a rod, and said they would send it off to Dr. Vanos for inspection if I go that route. |
10-20-2010, 09:11 AM | #5 | |
Rep 4,726
Whoever does it, make sure you ask them if they have ALL the vanos tools. The z4 is not like the e46 M3 where it can be done without the correct tools and a lot of places do it that way even though its wrong. The z4 CANNOT be done without the tools, because of the clearance in front of the engine, you HAVE to have the solenoid actuator, and even then it's a bit of a pain. If you ever need anything done and can drive to ORL, www.precision-sport.com
10-20-2010, 09:15 AM | #7 |
Rep 2,782
Hmmm. I guess I'm going to drive around at 8k rpm all the time now so that if it grenades, it does it right and destroys everything (kidding). When my warranty is up at 100k miles, I'll get the bolts fixed. Has anyone tried to get BMW to put out a recall on these bolts?
10-20-2010, 09:48 AM | #9 |
code monkey
Rep 74
10-20-2010, 09:55 AM | #10 | |
Rep 4,726
Probably a bad coil or plug unrelated.
10-20-2010, 11:39 AM | #11 | |
Rep 637
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
10-20-2010, 01:13 PM | #12 | |
BMW Fan
11
Rep 553
There are going to be a lot of these Z4Ms coming off warranty over the next months and with all the horror stories posted about dealer repairs, many owners will be reluctant to take the car back to the dealer after the warranty is over. One advantage to the dealer repair of course is the two year warranty they provide on their work. Perhaps it would be helpful if you could post your real name, contact numbers, and a detailed description of the services you can offer specific to the Z4M, for anyone within reasonable distance of Orlando. Thanks. |
10-20-2010, 01:20 PM | #13 | |
707
10-20-2010, 03:07 PM | #14 |
code monkey
Rep 74
I just heard back from the dealer - I did indeed have loose camshaft bolts. They said one of them was almost cut through entirely. They are having the bolts and gaskets overnighted, so I should have my car back tomorrow. My service advisor is seeing if BMWNA will help reduce the cost of the service at all, if not, I'm looking at about $1k.
I'll post some pictures of the bolts after I pick up the car tomorrow. |
10-20-2010, 06:27 PM | #15 |
Rep 2,782
Good to hear you were somewhat lucky and found the problem before the bolts actually sheared.
10-20-2010, 06:41 PM | #16 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Whew glad they found it. One reason im glad I don't have the 06 anymore. I was paranoid and always hearing noises and ticks. In fact before i lost her I was going to pull the cover and check for play Indicating loose bolts.
10-20-2010, 07:10 PM | #17 | ||
Rep 4,726
10-21-2010, 03:31 PM | #18 | |
Rep 606
My car went off of warranty a few months back and for issues I had documented while under warranty but were unable to be reproduced but now are able to be reproduced have been covered as a courtesy under warranty. Just to give you an idea... a week before I went off of warranty I my passenger headlight went out. They couldn't reproduce the issue and then a month after the warranty expired I was able to get it to not light up regularly. No charge to fix. Also, I had been complaining about the dust boots around the caliper piston deteriorating since I started bringing my car to this dealership. They never really took it seriously until 2 months out of warranty when I was able to actually point to the rubber completely falling apart. They understood that a seized caliper would be much more expensive than the $20 rebuild kit so they, again, did the repair at no charge. And, actually, the car is in right now for a TPS module issue that cropped up a few times before the warranty expired. At the time, they did a software-only fix and I knew that wouldn't resolve what was pretty obviously a hardware issue. Sure enough, it's being repaired no charge. So the precedent is well established that if there is an issue you've reported and had entered into your file that ultimately becomes more serious and/or more reproducible that it can (and should) be covered by BMWNA. It takes a VERY good Service Adviser, though, as they need to make the case to BMWNA. I call it the "I told you so" clause of post-warranty coverage. I don't know if you noted any of these things prior to your warranty expiring but, for anyone who is still under warranty, be extra diligent in communicating issues to your SA and make sure they put it in the file. If that issue presents itself in a more major way when you're out of warranty... it should be covered. That said... indy shops FTW.
10-24-2010, 02:09 PM | #19 |
code monkey
Rep 74
I ended up getting my car back on Friday. I'll take a picture of the bolts as soon as I'm back home, but 3 of them were sheared completely in half, and a few others had a notch where the thread was completely removed. The tech used Loctite on the updated bolts to help avoid this in the future.
The dealer ended up discounting me 20% on the labor, and giving me a free rental during the process. Total in the end came to just shy of $800. The engine is much, much quieter now. There are no fluctuations in RPMs at idle, and I haven't seen a rev dip on a cold start yet. It feels like a brand new car. I did, however, notice one new issue after I got it back. Pulling out of my driveway on an incline and making a turn, I could hear a "pop" as I turned the stearing wheel. I can usually reproduce it pulling out of my driveway, but if I'm sitting on a flat surface and turn the wheel lock to lock, it's not there. I remember the tech saying they had to lift the engine to work on it...could this be related at all to that? I'll likely take it back on Monday and have them look at it, but if anyone has something I can direct the dealer to look at, please let me know. To clarify - the noise occurs when I turn the wheel, moving or not, usually on an incline. |
10-24-2010, 04:13 PM | #20 | |
Rep 4,726
Pops probably not related, probably a spring making noise and you're noticing it now.
10-24-2010, 07:34 PM | #21 |
code monkey
Rep 74
I thought it was odd they said they needed to lift the engine. At any rate, here's the pictures:
