      07-28-2013, 01:10 AM   #1
3002 tii
3002 tii's Avatar
2285
For those with Linear Springs...
What heights are you running front and rear and does that include the use of a helper spring?
Follow for latest mods
      07-28-2013, 01:49 AM   #2
seank
enthusiast
seank's Avatar
48
Are you asking for spring lengths?
      07-28-2013, 04:58 AM   #3
Beedub
ride heights ???
      07-28-2013, 10:07 AM   #4
3002 tii
3002 tii's Avatar
2285
Spring lengths, ie 7", 6", 5.5" with helper, etc.
Btw reason I ask is because I'm considering upping my spring rates. I currently have 450# 6" front, 550# 5.5" rear but it seems the rear is a custom length only offered by AST. So am I the odd one out using a 5.5" rear and if so, do I need to order through AST or can I just go with a 6" that is more readily available from other brands (Swift, GC, Hyperco, etc.)?
      07-28-2013, 10:13 AM   #5
sabbanick
Drives: 08 SBM M coupe
5" with helper spring up front
4" in rear
      07-28-2013, 10:18 AM   #6
3002 tii
3002 tii's Avatar
2285
4" in rear
4" rear?? What shock are you using? Why so short? And when am I seeing you at the next track event???
      07-28-2013, 10:22 AM   #7
sabbanick
MCS with ground control weight jackers.
Ill be on tract come sept/oct...nothing planned asofyet
      07-28-2013, 10:28 AM   #8
3002 tii
3002 tii's Avatar
2285
MCS, baller!!!
How do you like the weight jacks? I'm going to get the car rebalanced and am thinking of picking those up. But I've also read (and don't understand why) that those only should be used with high spring rates. Other things I've read is that the spring can get unseated with the weight jacks... 'tis true?
I'm wait listed for the glen in Sept with CCA but ill be doing a 3 day PCA event in Oct at NJMP. Hopefully see you there bud.
      07-28-2013, 11:00 AM   #9
sabbanick
No issues thus far with them.
      07-28-2013, 11:58 AM   #10
dorifto88
Drives: 88 Nissan Pathfinder
5" front and rear on ast 4150s, tried helper springs but the car was (at its lowest setting) a little bit below stock ride height, so i took them off.
      07-28-2013, 02:39 PM   #11
3002 tii
3002 tii's Avatar
2285
Pics with 5" springs? Car must be slammed... unfortunately NJ roads aren't as forgiving so I still need enough clearance just to make sure I can get to/from the track without bottoming out lol. I think I have about 2 finger gap.
      07-28-2013, 03:23 PM   #12
dorifto88
not the best picture, but you get the idea.
this is the ABSOLUTE LOWEST the car can go in the front
      07-28-2013, 03:25 PM   #13
dorifto88
if you need a set i still have my 60mm helper springs
      07-28-2013, 03:45 PM   #14
seank
enthusiast
seank's Avatar
48
6.5 f and r
      07-28-2013, 03:46 PM   #15
seank
enthusiast
seank's Avatar
48
What brand and size is that rear tire?
      07-28-2013, 04:20 PM   #16
dorifto88
Michelin pss 265/35/18
      08-06-2013, 09:17 PM   #17
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
I believe mine are both 5 inch swifts, I need to double check, when I adjust my ride height
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      08-29-2021, 08:52 PM   #18
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
I am thinking about getting the Rogue Articulating Spring Perches.
What length spring would be best?
Currently, have Eibach lowering springs and the sitting spring height is 5.5", so I am thinking maybe a 4" spring would be correct to use with these?
      08-30-2021, 04:01 AM   #19
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
You'll be fine with 5.5 or 5"
Those running 4" springs are making a mistake specially if you track.
Instagram: ariusen26
Youtube: Track vids
