      08-29-2013, 07:41 PM   #67
CJW2OO4
CJW2OO4's Avatar
any update on the brighter festoon light? I am trying to piece together a kit right now.
      08-30-2013, 09:17 AM   #68
CJW2OO4
CJW2OO4's Avatar
      09-16-2013, 02:45 AM   #69
TestShoot
I1, I won
TestShoot's Avatar
Drives: E71 M, E60 535i
Just bought THESE for <$7. They do look whiter, but not brighter, infact, they are a little directional compared to globes. I hoped to put them in the cubby/rear console, but the wires must be broken.
I am not really convinced these days about interior LED lights so much. Globes are more likely to have spill light instead of spotty LED's. Ziza just seems too expensive when I am not so sure they are any better than what I bought online.
The LED strip light mod for the trunk however was a massive improvement.
+-============[tSc]==============-+
http://www.TestShoot.com
      05-19-2014, 10:29 PM   #70
shibby170
Drives: 2007 Z4M Roadster; 2017 M2
Originally Posted by XMetal View Post
For the center roof, I ended up using a 5LED 194 (shown in the attached picture). It won't fit through the hole opening, but you can easily remove the plastic cover (2 screws) to installed the bulb without needing for it to fit through the socket opening. I found that this 5LED bulb glows much closer to OEM (in terms of brightness) than the single LED.
For the trunk (boot), I used the 16LED festoon. Since the trunk only have 1 bulb, I want the maximum luminescent out of the bulb.
Can you provide a picture of the "two screws"? I see two things that look like they may be the screws you are taking about, but my screw driver doesn't fit in the narrow passage way to them.
      05-19-2014, 11:01 PM   #71
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
See attached picture
      05-25-2014, 12:58 PM   #72
Z4Lee
Z4Lee's Avatar
Drives: 2006 Z4 3.0i
Thanks for showing how to remove the clear plastic lens. I had managed to feed the two map light bulbs in by inserting the bulb from the front and connecting at the back, but i couldn't figure out how to remove the clear lens that covers the centre bulb. My 2 holding screws (2006 3.0i roadster) were in a slightly different place, but very similar.
Another small trick to point out, is that in removing this whole light assembly, start by prying from the left side which has the snap-catches, the right side is more of a hinge and should not be pried down (at least on mine).
      05-25-2014, 06:04 PM   #73
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Come to think of it, I may have grabbed the wrong picture. Looking at it more closely, that may have been the rear center dome light of my X5
      01-15-2016, 12:53 PM   #74
Kenchan218
Kenchan218's Avatar
Drives: E89 Z4
I managed to unplug the door panel light out and now I can't get it back in because the wire is too short!!!
What can I do now!?
Also how can I remove the top light box?
Tags
led interior light globe bulb
