09-10-2013, 04:51 PM | #23 | |
Rep 155
Thanks. Now my fingers are crossed. |
09-11-2013, 01:19 PM | #24 | |
Certified Adrenaline Junkie
42
Rep 1,325
Must be a Dallas thing. It does get damn hot here. Surprised I haven't seen ya around gmbbs, although Dallas is a big area. I am in Northeast Dallas, near Murphy, Sachse, Wylie, etc.. |
09-13-2013, 03:00 PM | #25 |
636
Rep 3,124
Well, I found the A/C drain. You might be able to reinstall it, if you have long tricky fingers.
I can't see much of the bulb end, but I can feel it laying under the car, feet pointed toward the front, reaching around the right side of the trans. About 6 inches fore of the trans mounts; about 2 inches fore of a connector (possibly the speedo). I'm pointing to the general area in the first pic. Pardon the blurriness. Sure enough, the nozzle end is next to the guibo and points directly at the right side trans mount. There's a tab on the side of the nozzle that sits over one of the sound absorber studs, and has a plastic nut over it. You should be able to look up the right side and see a stud, probably with a missing nut, to the right side of the guibo. Pics 3 and 4 show it from a couple of angles. Now I have to figure out how to attach an extension hose.
09-13-2013, 09:02 PM | #26 |
636
Rep 3,124
Well, it's a little less hokey
Used 5/16" I.D. Fuel Injection Hose from Pep Boys.
Decided not to put Fire Sleeve over it. If the speedo cable can take the heat, the hose can. Used a spring steel hose clamp, a couple of angle brackets, and a binder clip to clamp it to the trans brace. I think it'll hold.
09-18-2013, 03:16 AM | #27 | |
Rep 155
09-18-2013, 11:14 AM | #28 |
636
Rep 3,124
Yes.
The "bulb" end goes dead center into the top of the tunnel, with the "spigot" pointing rearward toward the passenger side.
10-19-2013, 10:02 PM | #29 |
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
Great timing!
I JUST installed a set of black UUC mounts with cups. Set had been in the box for about a year. Cups on the bottom, as they were notched, and seemed to fit better against the bracket, than the transmission (seemed like the cup didn't want to sit flush on the transmission's mourning face & may have required some filing/machining on a cup edge). Now I believe function is fundamentally the same whether they're on the top or bottom... but I see one issue with the way I have mine: potential fluid collection. Running the car with the defroster pumping yesterday had AC condensation dumping out over the bracket. Looks like I get the fun job of getting the car back up and AT LEAST re-routing he drain. Ugh! PITA!!! Anyone have any examples of the black ones deteriorating? Just curious. I'm 99% sure mine are poly, not the older neoprene rubber. |
10-20-2013, 12:49 AM | #31 |
636
Rep 3,124
Did you push on the heat shield in the tunnel and feel for a lump?
With the nut off, the heat shield may have slumped and swallowed it. Then again, it may have broken off. I can't imagine how, but it would explain why the duct fell off.
10-20-2013, 03:26 AM | #32 |
Rep 155
do i have to remove transmission mount to access it? i looked around the right side of the mount for hours but no clue. i removed a heat shield near this area but still.....o
10-20-2013, 06:04 PM | #33 |
636
Rep 3,124
Then it's probably broken off.
The hole in the heat shield has to still be there. Maybe you can put a screw through it with big washers on each side, and a nut to hold it in place forming a new stud. You should be able to find the exact location by trying to fit the duct back in, and see where the tab ends up.
10-23-2013, 10:30 PM | #34 | |
Rep 155
strangely, I did not see any speedsensor wire like shown in your pick. mine is 3.0si, so maybe mine is located at a different location?
what do I have to take off to see where the larger side of hose goes? transmission mount? exhaust pipe? I did not see any broken stud either. Maybe I was looking at wrong place? I mostly looked around of passenger side tranny mount. Even used inspection mirror but no luck. could you elaborate more where I have to look? Thanks. Quote:
10-24-2013, 02:19 PM | #35 |
636
Rep 3,124
Yes, the speed sensor will be in a different place, so not good for reference.
The hole for the larger end is in the center of the tunnel, about over the top center of the trans. I didn't take anything off. I could feel the big end of the hose just well enough to make sure it was seated. The small end goes rearward along the passenger side of the tunnel.
10-25-2013, 05:25 AM | #36 | |
Rep 155
10-25-2013, 12:02 PM | #37 |
10841
Rep 4,891
This guy had the same problems on his m3:
http://www.m3forum.net/m3forum/showthread.php?t=336026 So it's more common. Clearly the steel bolts are relative loosly 'glued' in the polyurethane (which acts as it's own glue I think). The strange thing is: UUC states that the engine mounts have a certain construction, that it uses "a bonded end plate plus an inner plate embedded in the urethane". On this picture it says 'generation 2', but clearly your mount doesn't have that. So maybe the newer mounts don't have this problem (or it's simply not true ) BTW I use standard (generic) rubber anti vibration mounts (40x30xm8) which have harder rubber than the standard bmw mounts (and cost next to nothing...)
10-25-2013, 04:05 PM | #38 |
636
Rep 3,124
The tunnel down the center of the car that the transmission lives in.
10-26-2013, 10:41 PM | #40 |
Rep 219
So a few things you can certainly derive from this thread:
-AC condensation drains onto transmission mounts in the Z4M... and seems to be bad for some polyurethane. -To date, only UUC Red poly mounts are depicted here (and on the M3 board) turning to mush. -The mounts that have deteriorated clearly are NOT the "Gen II" hardware UUC suggests is inside ALL their poly mounts (black or red). *Not that the different design would help much IMO if the poly simply turns to mush from the AC condensation, though* Again, I'd be interested in seeing if any black UUC poly mounts are doing the same. Also any evidence of the "Gen II" design in a black or red UUC Trans mount. I know I bought mine when the newer design was advertised on their site. I would be a bit miffed if I ordered directly from UUC and got something that was not engineered as depicted. |
10-26-2013, 11:26 PM | #41 |
636
Rep 3,124
And I would add that it was pretty lame of BMW to drain the AC from way up in the tunnel, right over the mount.
10-27-2013, 12:25 AM | #42 |
Rep 219
Yeah that is weird design decision, for sure. Living in Washington, not too often I'm running the AC. After seeing this thread, I cranked up the defroster one morning to get an idea how the condensation is drained (and specifically where). It absolutely pours out directly onto that bracket and dumps over the bushing in question. Crates only some surface rust on the stuck bushing... But still: how hard to route a proper drain tube!?! Absurd!
10-27-2013, 09:13 AM | #43 | |
10841
Rep 4,891
And that there was some kind of fungus/bacterial growth. I couldn't make out that the polyurethane itself was falling apart. Still rerouting the ac line is a good idea imho. (and contact uuc with this problem; they might want to fix it to retain their good name )
10-27-2013, 02:54 PM | #44 |
636
Rep 3,124
See posts #25 and #26.
It's a little Rubish, but it does what it has to.
