09-06-2013, 10:57 AM | #1 |
Certified Adrenaline Junkie
43
Rep 1,325
Check your non-oem Transmission Mounts
Hey guys.
I was prepping my car for this weekends track event and while crawling around under my car I noticed some funk on the passenger side transmission mount. I have the UUC Option 2 (DIY here http://www.zpost.com/forums/showthread.php?t=411452 ). The best way to describe it is orange slime. When I touched it, it was definitely some type of growth. So I decided to pull them out and see what was up. Attached is what I found. The A/C drain line is right above the passenger Trans mount and with the crazy hot summers we have in Texas, all that condensation was being dumped on the mount causing it to erode away. I have put the OEM ones back on for now while I figure out what my plan is. Also when I put the OEM ones back on, I noticed they had some rust presumably from that same A/C Drain. Here is a picture of what they used to look like new and my OEMs with the rust. |
09-06-2013, 12:19 PM | #2 |
Rep 1,546
I thought you used the caps? Or you did and this still happened?
either way man, sorry to see but good catch. love being part of a community of people who actually take the time to look over the car before track days. What are you going to replace them with? Guess it's time to get on dat der engine mount upgrade too?
09-06-2013, 07:49 PM | #3 |
Rep 11,667
Wow... Good catch!
I'm really surprised how they decomposed!
09-06-2013, 08:18 PM | #4 |
Bad Lieutenant
232
Rep 3,517
I've never had good luck with any of UUC's urethane products. The Rogue rubber mounts are just as good if not better than the urethane units.
09-07-2013, 02:19 PM | #6 |
Rep 5,328
shocking...
09-07-2013, 05:30 PM | #7 |
703
Good grief! Updating sticky.
I wonder if there was some kind of galvanic corrosion between the aluminum cradle, the bolt/nut? That would rot things out from the inside. Not my area of expertise though. Last edited by Finnegan; 09-07-2013 at 05:37 PM.. |
09-08-2013, 03:05 AM | #9 |
Rep 5,328
so severe they need to refund the full price for this product and go back to the drawing board imo.... Utter fail!!
09-08-2013, 10:11 PM | #10 |
636
Rep 3,124
Now I guess we need a mod to reroute the A/C condensation.
I checked my OEMs that came off. Tiny surface rust on one, but cosmetic only. I'll be sure to check the REs next time I'm under there. Been running the A/C a lot last 2 weeks.
09-08-2013, 10:19 PM | #11 |
enthusiast
48
Rep 1,695
09-09-2013, 09:55 AM | #12 | |
43
Rep 1,325
Well track day went great. Shifting felt much better after I put the OEM back in, looking forward to getting something stiffer in there. Thinking I didn't notice a change in the shifter feel because they gradually "dissolved" instead of just going out.
09-09-2013, 03:16 PM | #14 |
636
Rep 3,124
Yep.
The big end goes to the box for the A/C evap coil. Apparently the small end sits over the trans mount. Next time I have the car up I'll see if I can find it and maybe add some extension hose to the small end.
09-09-2013, 06:22 PM | #15 | |
Rep 155
Thank you! thank you! thank you! How do I put back that hose? That was the only part I found. Do I need any other ring or something? How do I make it to stay? Also could you describe how I can access it? Do I have to drop the transmission to put it back? Where is it located exactly? Would you take some pics for me if possible? Thanks a ton! |
09-09-2013, 06:41 PM | #16 |
Rep 251
Gents... I have RE urethane trans...> mounts and AKG motor mounts and they look like new 15 months after being installed.
OP - try AKG products.... they are cheaper and they seem to be pretty good so far. Plus they are made in the good old USA! Good luck. |
09-09-2013, 07:00 PM | #17 |
Rep 86
Coincidentally I was under my car this weekend, and found my red trans mounts have done the same exact thing, just the right side mount, which is the one the A/C hose drains onto. I need to research alternate trans mounts, and I'm going to extend the drain hose down below the trans mount level.
Funny that Blind32 and I are both in Dallas... |
09-09-2013, 08:06 PM | #18 | |
636
Rep 3,124
All I know is it has to catch water coming out of part #1 here. Follow the A/C lines from the compressor to somewhere under the passenger compartment to find where #1 lives. Apparently it's above the right side trans mount.
09-10-2013, 11:08 AM | #19 | |
Rep 155
That's the thread I started. So is that mean I have to drop the transmission? That's bad new. :-( How do you drop the transmission? How hard is it? Is it worth to drop the transmission to re-connect this hose? |
09-10-2013, 01:01 PM | #20 |
636
Rep 3,124
I think I'll put my car up on the stands and inspect the mounts and A/C drain this weekend.
I put RE mounts on about a month ago, and it's been a hot month. Better check and make sure I don't have the same thing going on. I'll try and find that drain hose and get some pictures, and maybe come up with a mod to drain it past the mounts.
09-10-2013, 01:29 PM | #21 | |
Bad Lieutenant
232
Rep 3,517
09-10-2013, 01:39 PM | #22 | |
Rep 11,667
