      03-23-2013, 03:24 PM   #23
mike519
mike519's Avatar
Drives: 2018 M240i
Originally Posted by Finnegan View Post
Nope. That exact sound is there on both of our S54 powered cars at that exact rev range.
Buy and RPI or Diablo--that will drown out the noise! Personally, I just don't drive the car much as the 3K-3.2K RPM speed.
One month till I pick up my Supersprint Race cans in Italy. Hope that will drown it out. Just bugs the heck out of me.
      03-25-2013, 01:05 AM   #24
Shaung
Drives: E92 M3
I have the same exact ticking noise.
      03-25-2013, 09:39 PM   #25
herragge
Drives: 2006 Interlagos Z4 M Coupe
Also have the same noise around 3k. Doesn't bother me.
      03-25-2013, 09:42 PM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There does seem to be a degree of difference from car to car with this sound.
I found that my M Roady was noisier than my M Coupe.
      03-25-2013, 09:49 PM   #27
jon1275
jon1275's Avatar
Drives: 2007 M coupe ILB
I complained about the same issue when I first bought the M. Service tech assured me it was normal noise of s54 valve train. Is it different that when you first bought car??
      05-10-2013, 12:36 PM   #28
Uncle Russ
Rocket Scientist
Uncle Russ's Avatar
Drives: '08 M Roadster
I've found my S54 ticking noise sometimes changes with oil changes and it was more pronounced after my first valve adjustment. So much so that I had the dealership re-check everything, including the VANOS, and their S54 expert said the same thing, "it's what S54 engines sound like." I'm not a big fan of the tick until the associated performance drowns out the ticking...
2008 ///M Roadster
      05-10-2013, 02:36 PM   #29
strokeoluck
Drives: 2007 BMW Z4 M roadster
I have the RPI exhaust and I can tell you that it helps drown out the noise, but it doesn't go away. Once your ear is attuned to the sound, I think it can always pick it up. Sort of the way my wife can instantly hear me when I mention her name 25' away from her at a party.
      05-11-2013, 02:39 PM   #30
mike519
mike519's Avatar
Drives: 2018 M240i
Just finished SS Race installation. Sounds bloody awesome! Can still hear the rattle though. I just can't believe this level of noise is normal...going to take it in somewhere that knows the S54s best.
      05-11-2013, 04:09 PM   #31
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
I don't know, I really don't hear anything unusual. I have a coupe with rpi. The motor does sound more mechanical than ur average car, but I don't have any ticking bothering me. Maybe it just doesn't bother me, I dunno
instagram: @ dubsesd
      05-11-2013, 10:49 PM   #32
strokeoluck
Boy, I can sure hear it. And I've taken it to the BMW dealership as well as a quality indie shop, and they both say it's a normal sound for the M. If I ever sell this car, that d*mn sound will probably be the primary reason I sell it - it just doesn't sound "normal" to me.
      05-12-2013, 10:53 AM   #33
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
OK I have to ask the tired question.
What are your oil change intervals?
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      05-12-2013, 03:04 PM   #34
mike519
mike519's Avatar
Drives: 2018 M240i
Can't tell you before I bought it but service records seem to indicate it was well serviced. I just changed the oil this past winter...less than 500k on it since.
      11-22-2016, 02:26 AM   #35
Boosted 1
Where Does He Get Those Wonderful Toys?
Boosted 1's Avatar
Drives: 07 M coupe, Gx470, M2 PE
This is going on with my 07 Z4M right now. Its been 60k+ miles since a valve adjustment so I'm hoping thats it. I don't have any codes, I'm not down on power and it still pulls really hard, MPG is stable. Its just a faint ticking around 2-3k rpm. It doesnt make ANY other ticks at any RPM. Should I go ahead with the valve adjustment and check everything while I'm in there? I'm paranoid of failures, and I'm not really sure what "normal" s54 ticks sound like
Talk about bringing a post back from the dead!! LOL
      11-22-2016, 11:12 AM   #36
StickMon
StickMon's Avatar
Drives: 2006 MR
I would definitely recommend a valve adjustment at this point.
Also gives you a chance to inspect the exhaust hub and other whirly bits.
      11-22-2016, 01:02 PM   #37
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
The Vanos activates around 3k RPM and the loading in the valve train is changing at that point which seems to contribute to more rocker arm noise. Just be thankful the Z4M S54s don't have the high pressure oil flow whine the earlier E46 S54s did. Sounds like a small jet engine under the hood.
Top Down 365
      11-22-2016, 04:37 PM   #38
Boosted 1
Boosted 1's Avatar
thankfully no whirl noise to deal with, just a slight tick. I guess that's the normal sound.
I read yesterday described as "sounds like bacon frying"
      11-22-2016, 05:33 PM   #39
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
It might only be the noise of the fuel injectors. Mine rattles too-even with super low mileage- i just crank up the radio!
      11-23-2016, 06:09 AM   #40
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Any engine with solid tappets (vs. hydraulic) are going to make noise. Go listen to an old M20 in an E30, it sounds beautiful.
      11-23-2016, 08:55 PM   #41
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
I had that same noise around 2800 to 3400 rpm. I just did a valve adjustment and they were ALL out of adjustment. All 24 valves! The sound has all but ceased. Very happy! There is still a change in pitch around 3k but it's much less noticeable now and so much more tolerable. I feel like it's a tighter engine. Bottom line: check your valves.
      11-24-2016, 06:10 PM   #42
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
wow, thats extremely unusual!
Is that the first time its been done?
how many miles?
BTW - you need to update your user profile.
You still show your car as 3.0si
....had me going for a moment re the valves on it
      11-24-2016, 06:33 PM   #43
garz747
How do u avoid that rev range on the highway? Its right at a nice cruise speed in 6th.
      11-24-2016, 07:18 PM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
not a problem if you are cruising along at a steady rpm.
The noise is from the vanos advancing.
It you stop accelerating the vanos also stops advancing
