New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      02-11-2023, 06:06 PM   #1
Dooker
Drives: 2011 E89
Chasing Lean Code bank 2 and MAF codes
Hello,
I have been troubleshooting P0174 (lean bank 2), P0100 (MAF A circuit) and P0113 (air intake circuit A high).
I have cleaned and ultimately replaced the MAF sensor with OEM. No change. I have checked the pins in the connector, they are in good condition.
I have smoke tested the intake twice. I cannot find any leaks. The inlet ducts have been removed and inspected and no cracks tears etc. When performing the smoke test and I remove the oil fill cap, I do have smoke coming from the oil fill port. I’m not sure if this is normal or not.
Any other ideas or things I need to check?
      04-19-2024, 09:01 PM   #2
andrew_fast
Drives: BMW Z4 35is
you want to change your O2 Oxygen Sensor. Pistons 4-6 is for bank #2
How many miles do you have in your car?
