02-10-2008, 03:16 PM | #1 |
Rep 195
It finally happened...
Well my tire pressure warning came on this morning while I was out for a short drive. I stopped and checked the tire pressures and my rear driver side pressure was down to about 28 PSI (Recommend: 39 PSI). Inspected the tire and found a nail in it. Looks like it occured some time in the past 2 days and has been a slow leak.
So I am contemplating getting it just fixed at a reputable tire place if possible. It is in the tread area and > 1" from the outer tread lines. I didn't run on them with no pressure or too low of a pressure so the side walls should still be in good condition and am hoping the tire is fixable. If not I'd have to dish out $330 for a new RFT tire!!! I have heard the stock RFT's wear out < 20k miles. So this may be my chance to switch out all 4 tires for non RFT's. I have heard a lot about the Goodyear Eagle F1 GS-D3 and Michelin Pilot Sport PS2, but I found the Sumitomo HTR Z III on tirerack.com and they have a pretty good tirerack rating as well as user reviews (?? comparable to the F1 and PS2). Plus the whole set of 4 would cost me < $600 . I lease my Z4 and figure I can just toss on the RFTs when my lease is up instead of potentially having to replace all 4 RFTs due to treadwear by the time my lease is up (4 x $330 = $1320). http://www.tirerack.com/tires/tires....=(Y)&minLoad=S Any one here have any personal experience with having had RFT's fixed? Any one with any info regarding the Sumitomo HTR Z III tires? Any other helpful comments would be appreciated. TIA. |
02-10-2008, 04:19 PM | #2 |
Rep 815
Had this exact same thing happen within the first 1200 miles I had my '07 coupe. Drove down to the local tire shop - Off, patched, on, 15 minutes and 20 bucks later I'm out the door and fine ever since. Unless you're near the point where you're going to replace the tire anyway just get it patched and forget about it.
02-10-2008, 04:55 PM | #3 |
Rep 1,210
Had the same thing happen to me, driver side rear. Sidewall puncture so it was unrepairable. Picked up a set of Toyo T1R, have the other 3 Bridgestone RFT in my garage.
02-10-2008, 05:29 PM | #5 |
Rep 195
vachss and Artz,
how long can I expect the patch to last? |
02-10-2008, 06:02 PM | #6 |
Rep 4,365
A patch will last as long as the tire lasts usually. They are not a 'temporary' fix as some thing.
02-10-2008, 07:15 PM | #7 |
your average JAMF
3158
Rep 4,101
Trust me - get rid of the RFT's ***NOW***. It WILL be the best $$ you ever spend on your car, you'll be back here thanking me and raving about the improvements in handling, comfort, turn-in, and probably even a reduction in global warming and worldwide hunger. RFT's are the devil, anyone who's had them then come back from the dark side on the same car has the EXACT same experience.
I rented a turd of a Pontiac G6 while in SoCal the past few days. The multifunction display tells you exact PSI at each corner. If GM can put that in this rolling embarrassment, then why can't BMW give us that functionality, rather than just a cheesy idiot light that comes on after a huge amount of pressure is already gone? Riddle me that, Batman.
'21 M2 Comp
'19 Golf R |
02-10-2008, 09:28 PM | #8 |
Rep 13
I just dumped the RFT's on my 07 Coupe...Kevin C's right, easily the best $$ I have spent on the car...went with Yoko S.drive, very, very happy, the improvement in ride quality is practically beyond measure, have heard great things about the Goodyear F1's, unfortunately the rear's were out of stock when I made the switch (apparently Goodyear ran out but has scheduled a production run soon)...good luck
02-10-2008, 11:43 PM | #9 |
Rep 4,365
As soon as the ice age passes I am getting some new wraps... But as long as it is -44 degrees with windchill and we get 13 inches of snow in 24 hours (last tuesday) there is no need.
Come on summer!
02-11-2008, 12:15 AM | #10 |
Rep 1,210
Some troll @ Firestone tried to tell me my Toyo's are junk and the OE 18's will perform better with the Bridgestone RFTs. Then proceeded to say I was fortunate to find a company that would do the dangerous act of putting the Toyos on my rims.
02-11-2008, 05:03 AM | #11 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
RFTs are dumb.
You have to be 100% behind someone before you can stab them in the back.
David Brent |
02-11-2008, 07:07 AM | #12 | |
Rep 1,191
you CAN patch run flats just like regular tires if you don't need to spend money on tires yet, just keep em till it wears out. why spend $1000 when u got a perfectly good tire? Stock RFT RE050A's are sticky enough. but when it comes to getting a new tire, of course the non-RFT's
2022 GLE 53 Coupe
02-11-2008, 09:52 AM | #14 | |
Car Guy
31
Rep 796
But I guess this is coming from a Firestone employee
02-11-2008, 04:00 PM | #15 |
Rep 195
Well took the car in today during my lunch break (it's one of the authorized installer's for Tire Rack and very reputable place with good customer satisfaction around here). They took close to an hour but they patched it. They said they had to take a litte extra time and caution it being a low profile tire... anyway an hour later and only $21 less I was ready to go. I am still planning to switch over to non-rft's and will give the Sumitomo HTR Z III a try, but will wait until I put a little more wear on the RFT's first.
Thanks to all for your input. |
02-11-2008, 04:58 PM | #16 |
Rep 1,689
Sumitomo = made in china crap.
GoodYear F1 from personal experience are horrible in the rain. No wet grip whatsoever. I'd take the Michelins over the Goodyears. Personal favourite right now is the Nitto Invo.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
