      02-22-2008, 02:40 PM   #45
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Most people that have that problem go with the concealed display its about 1/2 the size of the V1 face and can be easily hidden in the dash, ashtray, etc.
      02-22-2008, 08:34 PM   #46
Hawkeye
Hawkeye's Avatar
No_Country
2070
Concealed display is extra I take it? I'll do some more research Thanks.
      02-22-2008, 08:49 PM   #47
BimmerZealot
Concealed display is 39$ option
      02-22-2008, 09:18 PM   #48
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
bimmerzealot can you look at my post at the end of the previous page (i think you missed it). I need some assistance. thanks
      02-22-2008, 10:58 PM   #49
BimmerZealot
Sorry I missed that. You want to use the rear view wiring harness. It will be towards the back of the dome light housing. It's prewired for a universal garage door opener even if you dont have one which is why it has a power wire in it. To get to it you can take a flat head and open up the base of the mirror assembly (clam shell I think is what people call it) inside you'll find the plug and the wiring harness. I remember not being able to unplug it so I just reached into the opening, located my wire (probably wrapped) and spliced it without unplugging the wiring harness. Let me know if this helps.
      02-24-2008, 12:12 AM   #50
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
im just going ot use the space i have up in the map light assembly. going to be a PITA but will be worth it. also i will be tapping the purple wire with white stripe like the OP. wish me luck. thanks zealot. ill let you know how it works.
      02-24-2008, 01:29 AM   #51
BimmerZealot
Ya thats what I ended up using cause unplugging it wasn't possible for me, I'm sure it's doable though. Also have a list of wires handy when you do it because your carry might vary slightly. Or if you have a voltmeter that would be your best bet to test which wires get power when the key is on slot 2 and dont when its not.
      02-26-2008, 09:43 AM   #52
rc'Z
Drives: 2009 335i Convertible
Originally Posted by Hawkeye View Post
Soo.. I have never had a radar detector and they are illegal here in IA... Where do you guys keep the actual detector since it is hardwired? Is it still easy to detatch and take down if you do happen to get pulled over? Also, how noticable is it? I have a black coupe so I am thinking up by the rear view mirror shouldn't be too noticable.
I am pretty sure this is the way I am going to go if the answers are right.
I never heard of them being illegal in IA, only DC and VA. Any body else weight in on this one?
      02-26-2008, 07:28 PM   #53
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
I got it done with the green wire with white strips. Everything else was easy. Thanks bimmerzealot
      02-26-2008, 07:49 PM   #54
BimmerZealot
Good to hear you got it to work. Congrats
      03-14-2008, 07:21 PM   #55
The HACK
The HACK's Avatar
1821
Originally Posted by Justincase View Post
did we ever figure out what wire it is for the premium package Z4M ?
You don't need to.
BMW wires are COLOR CODED. Lavender wires are live with 12V power at switch position 1. The strip color determines the amount it is fused. The minimum fuse is 5AMP. No strip means un-fused power (danger! Do not tap!). Green wires are live with 12V Power at switch position 2. There are a couple of other color wires I have yet to figure out what the color stands for, but they all supply power in a specific fashion. For example, the wire that I tapped for the UGDO installation (see thread here: http://forums.bimmerforums.com/forum...highlight=UGDO) supplies DIMMED power (meaning it dims with the headlight dial, same as the stereo on the dash) is grey with red stripe. I haven't dug in the back of the stereo to see if the grey wires are indeed dimmed power when headlight is switched on.
I've dug into the E9X overhead console and the color scheme is identical. Lavender = switched 12V at 1, green is switched power at 2.
      03-15-2008, 04:29 PM   #56
BimmerZealot
Very informative post thanks, good to know
      03-17-2008, 10:48 AM   #57
caseysc
caseysc's Avatar
Drives: 2010 128i Conv.
2005 Z4 2.5i  [8.00]
Check on bimmerfest - search V1 hardwire
      03-20-2008, 01:02 PM   #58
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
I have V1, but I don't have the hardwire kit, which kit on the V1 website is the one I need for a hardwire? Or could I just go to Radioshack?
      03-20-2008, 01:42 PM   #59
Hawkeye
Hawkeye's Avatar
No_Country
2070
Man, you really need to read the threads before posting
      03-21-2008, 12:31 AM   #60
aztec
Bean2GO
aztec's Avatar
Drives: 2017 BMW X4 M40i
According to the National Conference of State Legislatures, radar detectors are banned in all vehicles in the state of Virginia and the District of Columbia, Washington D.C. Radar Detectors are also banned in big trucks in the states of New York and Illinois. Plus, under federal law, the use of radar or laser speed detectors is illegal in all commercial vehicles over 10,000 pounds. However, radar detectors are allowed in all noncommercial vehicles in all other states.
      03-27-2008, 05:32 PM   #61
Black///Mamba
Black///Mamba's Avatar
53
Drives: a beast
so i finally ordered my V1 and received it today. i am soconfused as to even how to take down the dome light. ughhhhh...this sucks. i just want my V1 in the car! it doesn't even work in the ashtray power supply.
Once I get the dome light fixture down i am pretty sure I can figure it out.
      03-27-2008, 08:56 PM   #62
BimmerZealot
You just use a small flat head screw driver wrapped in a towel and pry it out from the front towards the back, or maybe back towards the front one of them has hinges one has springs.
      03-27-2008, 10:31 PM   #63
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
i used a butter knife. risky but worked like a charm. This is easy black///m pm me if you need any help or post it up here
      03-27-2008, 10:41 PM   #64
Hawkeye
Hawkeye's Avatar
No_Country
2070
I could have sworn they were illegal in Iowa as well...
      03-28-2008, 08:57 AM   #65
Black///Mamba
53
Drives: a beast
you just stick the knife covered in a cloth in between it and just kind of wiggle it out?
      03-28-2008, 09:27 AM   #66
Starscream
Starscream's Avatar
can all who have installed a V1 PLEASE post pics of what it looks like in a Z4,
to date I have never seen a picture of one in a Z4 and I want to see how far it sticks out
Roadster really, but even a coupe would do!
Imola Red Roadster
