02-17-2014, 11:15 AM | #1 |
Rep 70
engine oil
Hi all, I need to add oil on the engine of my z4 3.0 si coupe(at 82000km)?
I was recommended Castrol. Which brand is the better? Regards Kadir |
02-17-2014, 01:57 PM | #2 |
Rep 92
I just use the original BMW oil some say it's just re branded castrol but it's only a few bucks more and u know for sure I paid $6.50 per quart from the dealer and change it myself
02-17-2014, 01:58 PM | #3 | |
Rep 1,034
02-17-2014, 01:59 PM | #4 |
Rep 70
02-17-2014, 02:00 PM | #5 | |
Rep 70
02-20-2014, 01:18 PM | #7 |
Rep 70
this what I could find in the seller. I add only 1 litre on the engine and and the yellow warning stopped.
It matches the spesificatioın you gave to me. But I have a question now that should I use 5W-30 or 0W-30, which one is better? On the other hand I consider to renew oil in the engine completely? Is it make eany difference in the performance? Is better oil better performance? thanks for all post from you. regards |
02-20-2014, 08:34 PM | #8 |
///M-fanatic
193
Rep 3,885
Mobil 1 full synthetic 0W-40 should be just fine. Relatively cheap if you purchase 5-quart jugs from Walmart. Then buy some OEM filter kits from like Tischer BMW ( http://www.getbmwparts.com/partlocat...egoryID=103121) or something. I believe the non-M engines use the same filters as E46? I could be wrong, but you can still navigate that site as needed and purchase what you want.
02-21-2014, 12:06 PM | #9 | |
Rep 70
As for filter I ask for my service to change it when I completely change oil. regards |
02-21-2014, 12:28 PM | #10 | |
Rep 70
02-21-2014, 02:49 PM | #11 | |
///M-fanatic
193
Rep 3,885
M engines require 10W60. |
02-21-2014, 04:50 PM | #12 |
Rep 70
02-21-2014, 05:54 PM | #13 |
Rep 2,543
02-21-2014, 06:46 PM | #14 |
Rep 70
02-23-2014, 07:14 PM | #15 |
///M-fanatic
193
Rep 3,885
06-29-2014, 04:56 PM | #16 |
Rep 70
Hi all, today after stop my car I had a warning on the screen displaying engine oil pressure sign. I checked the manual and then checked engine oil level. It needs to be added 1 lt new oil. Actually I'm suprised because I fully changed engine oil in BMW service about three months ago with Castrol Full syntetic 0W-40. Now I need your ideas. Is it normal engine oil requirement in a short time about three months? It's 2007 3.0 si coupe.
06-29-2014, 07:26 PM | #17 | |
///M-fanatic
193
Rep 3,885
06-29-2014, 07:34 PM | #18 |
Rep 70
Valve cover leakage? I'm getting be scared already now
06-29-2014, 08:21 PM | #19 |
///M-fanatic
193
Rep 3,885
07-06-2014, 07:58 PM | #20 |
Rep 406
And how many miles did you drive in the 3 months? Milage, not time is going to tell us if you have a problem or not. Using 1 litre every 1-1.5 thousand miles isn't uncommon.
Sent from my smart phone...
07-10-2014, 06:24 AM | #21 | |
Rep 70
By the way I went to BMW service. Service guy says burning oil is normal in BMW models. He changed oil with 10W-60. Now I will monitor how long will it take. |
07-10-2014, 09:45 AM | #22 |
///M-fanatic
193
Rep 3,885
Why would they put 10W60 in a non-M engine? I think that is too thick an oil for your engine...
If they're trying to prevent oil from burning by introducing thicker oils, then I think you should stay away from servicing with them in the future |
