11-13-2013, 09:55 PM | #23 |
Rep 12,565
Omg you're alive
11-14-2013, 02:50 PM | #24 |
Rep 711
I considered doing that when I got my strut bar but I didn't want to drive around for a week without my firewall braces on, so I went the other route.
I think the Aluminum looks really good. I think I like it better.
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| |
03-27-2014, 03:30 PM | #25 |
Rep 258
Sorry to bring an old thread back to life. I bought my front strut bar and had it power coated as well.
The problem i'm having though is, the factory upper mount nuts are too big to fit in the strut bar plate's recessed holes. Did you guys have to get new nuts? If so where did you get them from? That's the only thing holding me back from installing it |
03-27-2014, 04:18 PM | #26 | ||
Rep 711
I found these referenced on another forum. Maybe you can check these out and see if they work. Quote:
03-27-2014, 05:57 PM | #27 |
Rep 258
I appreciate it, I'll check it out tomorrow. As far as i can tell, mine only came with the nuts for to bolt the bars and plates together. and i have to reuse my factory nuts, and they don't fit. I'll double check just to be sure. If not, well at least i hopefully have the right part numbers
03-27-2014, 06:07 PM | #28 |
"The Midas Touch"
519
Rep 1,055
Drives: F87 LBB ///M2
Does anyone know what size are the strut nuts for the back bars and front as well as the nuts that hold the bar to the side plates? Working on a special project! . Thanks in advance!
03-27-2014, 06:13 PM | #29 | |
Rep 711
03-27-2014, 06:28 PM | #30 |
"The Midas Touch"
519
Rep 1,055
Thanks! Which is for which?
03-27-2014, 06:38 PM | #31 | |
Rep 2,138
Drives: Me
03-27-2014, 07:05 PM | #32 |
Rep 711
I can't remember but luckily you need 4 of each
I'd wager M8 is strut brace and M10 is firewall.
03-28-2014, 11:23 AM | #33 |
Rep 258
Dangit. I ended up looking in my center console again curiously... found the "new" nuts that even have dowels built onto them... So, Never mind, i'm an idiot, and BMW gave me all the parts i needed. yay! /facepalm
04-09-2014, 09:05 AM | #34 |
Rep 12,565
Thanks for the Fastenal part numbers? Do you know if Fastenal also has the replacement nuts C-lost needed (BMW p/n: 51 717 895 241)? Those ring up at nearly $10 EACH from BMW...
04-09-2014, 11:27 AM | #35 | |
Rep 711
That I don't know. Mine came with them, so I never looked.
06-19-2014, 12:52 PM | #36 |
"The Midas Touch"
519
Rep 1,055
I just checked my firewall braces and the fasteners that I have are 16mm bolts not nuts? My E86 M is a 08. Is this normal? Does anyone know the sizing on these?
06-19-2014, 12:55 PM | #37 | |
Rep 711
Not sure on the sizing, sorry.
06-19-2014, 05:23 PM | #38 |
"The Midas Touch"
519
Rep 1,055
06-19-2014, 06:10 PM | #39 | |
Rep 711
http://www.zpost.com/forums/attachme...5&d=1335210055
06-19-2014, 06:51 PM | #40 |
"The Midas Touch"
519
Rep 1,055
Yea thats it! Looks like a M10x20? But on my firewall braces both ends are bolts so I'm assuming both would be the same? The diagram looks like it shows a nut and a bolt (2 types of bolts)?
07-06-2014, 08:30 PM | #41 |
"The Midas Touch"
519
Rep 1,055
For the 6 strut bar nuts has anyone gone with just normal M8 nuts without the color and had any issues with the camber moving and adjusting for those with coil overs since the strut tower holes are adjustable?
07-10-2014, 12:56 PM | #42 |
"The Midas Touch"
519
Rep 1,055
Anyone?
