      07-27-2014, 02:57 PM   #1
Spedracer81
Drives: Z4MC
Exclamation to suck or not to suck...
I'm about ready to do my 3rd oil change, I have bought the suction tool to suck oil from the dipstick, works great but I feel like I'm not getting it 100% empty. I bough the new drain plug and I just wonder if I'm being OCD by wanting to drain the oil from from under the car, my thinking is that I will get all the oil and whatever debris is in there...I'm I over thinking this?
| 2008 Interlagos Blue Z4MC |
| AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust |
      07-27-2014, 03:08 PM   #2
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
I get more oil out of it with my Mityvac than I do by draining...
2006 Z4MC - #LL93158
      07-27-2014, 03:10 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
If you're going to replace the drain plug seems like a waste of time to suck.
What kind of drain plug?
I put in a magnetic Dimple plug (SS M12X1.5X12) from BavAuto.
I was surprised to see how much swarf came out the next change. Been clean since.
I don't know if it was just 100k miles worth of rings, or bits of my broken vanos exhaust hub.
Nice to know it's not in there any more.
      07-27-2014, 03:50 PM   #4
Spedracer81
Drives: Z4MC
the past two times I sucked the oil out, I bought the oil change kit from Tisher, it comes with a new plug..I'm kinda curious to see whats stuck to the magnetic plug..at 50k should I continue to suck oil or drain?
      07-27-2014, 05:47 PM   #5
Spedracer81
Drives: Z4MC
well I got bored and drained the oil, turns out it must have been done this way before b/c the plastic cap was missing, and BMW never replaced the drain bolt with a new one ( still hex OEM plug)
All and all, not bad I feel better about it knowing that I got 99% of the oil removed...on to the next project..
      07-28-2014, 06:02 AM   #6
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
I believe only M3's had the plastic cover over the oil drain bolt. My M Coupe didn't have one and TIS infers that prying off the cover is e46 only. I've got a mightyvac rig. I usually alternate between sucking and draining.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      07-28-2014, 07:23 AM   #7
Spedracer81
Drives: Z4MC
Wasn't sure, I found a diy and it said remove cover, wasn't there..but I think I'm going to alternate between sucking and draining...wasn't too bad getting under there and draining..
      07-30-2014, 12:48 PM   #8
speddmn
Drives: 05 3.0i
my 3.0i has a door under there, it catches oil fantastically and blows sh*t all over the floor!
bags are for groceries.
      07-30-2014, 07:15 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
This plastic cover?
I have one.
It didn't have one when I bought it used.
I expect mechanics don't bother to put them back on.
