      04-10-2008, 08:49 PM   #45
Dieselino
Dieselino's Avatar
47
Drives: 03 LSB M3 06 M coupe 08 M3 SG
UPDATE:
Bought some professional strength Goof Off from Home Depot to give it a try. I applied alot of Goof Off on a paper towel and kept rubbing it into the visor to try and remove the glue. After a couple applications I managed to remove the remaining residue!
However in doing so it caused the visor material to wrinkle. At this point I thought my visor was toast because I wasnt going to be able to live with the wrinkles. So I took a heat gun to it. I heated up the wrinkled area really good with the gun and I kept swiping my hand across the visor to move around the wrinkles. I kept smoothing out the wrinkles with my hand while still keeping the heat gun going and voila! Wrinkles went away!
It was a pain but I managed. Looks like Goof Off is a must!
Originally Posted by Dieselino View Post
After reading this thread I first tried the dryer method and it didnt work to well. I then tried brake cleaner and it worked like a charm as long as I kept the label drenched in brake cleaner the label came right off.
Now for the life of me I could not remove the residue. I tried the following:
1) Scrubbed with a scouring pad with more brake cleaner
2) Isopropyl Alcohol 70 and 99%
3) Nail Polish remover
4) Mineral Spirits
5) Laquer thinner (this causes discoloring)
6) Paint Thinner
7) Goo Gone
Only thing I havent tried is Goof off but I find it hard to believe it will remove the residue if all these other products wouldnt. Any ideas?
      04-10-2008, 09:15 PM   #46
takedown8
takedown8's Avatar
Drives: 2005 BMW Z4 3.0i
Hawkeye, you really should remove the visors before doing it. It's just so much easier, and you can apply pressure better.
I would suggest you remove the one with the black residue on it (just two screws to remove), and go at it with circular motions with moderate pressure using a good, rough sponge or even steel wool.
      04-11-2008, 09:34 AM   #47
Hawkeye
Hawkeye's Avatar
No_Country
2070
They come off??? I was in a hurry and couldn't figure it out quickly so I improvised... Perhaps I'll find those pesky screws this weekend.
I was scared to use something too rough, but perhpas I'll give that a try as well. Thanks!
      04-11-2008, 07:17 PM   #48
takedown8
takedown8's Avatar
You didn't read intgr8r's original DIY post did you?
      04-11-2008, 07:47 PM   #49
Burt Reynolds
Burt Reynolds's Avatar
53
Drives: 2007 M Coupe
I used some of my wifes fingernail polish remover and a shop cloth with a hairdryer- worked like a charm. I finished it off with a little leather conditioner and looks like new.
      05-18-2008, 02:26 PM   #50
speedygirl
speedygirl's Avatar
Drives: 2006 Z4 3.0si, Jet Black
+ 1 for Goof Off. Whole job took about 10 minutes.
Nooooooooooooooo!
      04-17-2010, 04:21 PM   #51
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Bump to a super oldie but goodie thread.
I removed these from my Extended black leather on Wednesday. Still a faint rectangle of where it used to be if held in the right light at the right angle but much much better than a big ugly sticker. Plus once they are reinstalled you will never see the rectangle even if you look for it.
I used Goof Off, same bottle as Reach did. Found it at my local Lowe's. They had the aerosol spray can and the bottle cap open type like shown in picture (not sure what to call it, just a normal bottle of it with a lid). Went with the non-aerosol type for ease of use.
Originally Posted by Reach View Post
This stuff is serious business. Works great at removing gunk. I've never really used goof off or goo b gone, etc.. and I'm impressed...almost scared. I hope I still have my fingerprints after this. Anyways, I can't be held liable if you remove the finish off of your wifes kitchen table while doing this. I did it on marble and was fairly confident it wasn't going to eat into the granite, and it didn't.....yet.
I first removed the sun visors from the car. Then I took a red shop rag and applied the goof off to the label. I just coated the entire label generously so it was all wet. I let it sit for about 3-5 minutes. I then just took the goof off rag and started scrubbing it softly and it came right off. Be sure to move to another part of the rag as you remove the label. After it was all off, I got a wet paper towel and wiped it down and did the other side. I applied some Meguiar's Gold Class Rich Leather Spray to it reinstalled and enjoyed. I also ended up cleaning/conditioning all my leather and it feels good as new. I recommend everyone do this so that no one tries to put the baby in the back seat
Sorry for crappy iPhone pictures.
      04-17-2010, 04:25 PM   #52
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^Nice
lol.... have to have a go at this myself; one more time.
The heat method was great for me the last time so I'll try it that way one more time.
      04-17-2010, 05:22 PM   #53
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
100% acetone gets the job done and is much cheaper and than goof-off.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      04-17-2010, 06:28 PM   #54
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Yeah Goof-Off works great for this, and eventually the faint rectangle will disappear as that area fades from the sun.
      04-18-2010, 09:38 AM   #55
crfine88
crfine88's Avatar
442
Drives: E86M
I really need to do this. Thanks for all the great tips guys
      05-14-2010, 11:07 PM   #56
mhrir
Drives: Very fast
+1 on the Goof Off. The stuff has 1000s of uses (ok maybe 100s). I also have extended leather and the stickers have been on there for almost 3 1/2 years. The passenger one looks perfect. The driver's has a faint ghost but requires a certain angle to see. I wish it was perfect but I can live with it. If you are really sensitive to not having your car "perfect" then I would probably not risk it. I thought long and hard before doing it because I was working with leather instead of vinyl.
      05-15-2010, 07:16 PM   #57
RBull
Well, I guess I'm in the camp that this isn't working for. I've done the heat it up scrape it off and was still left with a shiny residue and plenty of wrinkles on the drivers side. Tried isopropyl alcohol and that did nothing. Goo gone was also useless. Brake parts cleaner made a slight improvement but it's still an embarrassing mess.
Very frustrating when others aren't having a problem using the same methods. I'll have to try and find some goof off although that may be difficult in my small city. The next option is probably to buy new visors and leave the stickers on. That should only cost $500 or so around here.
      05-15-2010, 07:55 PM   #58
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Dang.... that sucks
An option would be to have an upholstery shop recover them.
I haven't attempted mine yet.
      05-16-2010, 09:13 AM   #59
RBull
Dang.... that sucks
Thanks.If it comes to that reupholstering might be a good option.
I'm going to look for the goof off.
It's interesting there seems to be a wide range of difficulty in removing them.
      05-16-2010, 09:33 AM   #60
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Get the goof off.Works. Hope you can find some. Any home depot's in NS? Ace Hardware? They both have it.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      05-16-2010, 09:44 AM   #61
RBull
Thanks. Yes, there are 2 Home Depots in my area. No ace hardware.
I'll try that first.
      05-16-2010, 10:03 AM   #62
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I noticed that, even within the same car; right & left.
My first ones were unique to the Canadian cars, so that's also another factor.
I'll probably give mine a go tonight, I'll post my results.
      05-16-2010, 12:35 PM   #63
RBull
Well, bought some goof off. Definitely takes the stuff off after saturating with it and some gentle rubbing with a MF. The passenger side is okay. The residue is removed and the outline is barely visible. There's a small bulge starting on the edge that I decided to leave alone after the driver side experience.
The drivers side is terrible. What I found is the vinyl stretched big time. I tried gently heating and working it with my fingers. I had to quickly stop as the heat started to expand the h out of the vinyl. It's bulging out all over the place. Looks terrible. I might try working at it some more like dieselino did although when I was doing it before it got much worse.
      05-16-2010, 01:01 PM   #64
RBull
UPATE:
I went back at it again with the heat gun. Managed to get the wrinkling out to a point where it's not totally obvious, by heating and smoothing with my whole hand. This took numerous repeats. It's still a bit lumpy because the backing actually seems to be compressed whether it be from the heat or the goof off.
In hindsight I would not let the goof off set for several minutes and would use it more sparingly. It caused a lot of wrinkling that I didn't see on the passenger side where I used small amounts and worked it off immediately.
This isn't a mod for the faint of heart.
      05-16-2010, 04:13 PM   #65
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Got mine done.
IDK..... I still like the heat method
These came off just as easy as the 1st time, but there was definitely more glue residue left behind.
I had to do a final wipe with Goof Off to clean it up.
I would also say that there is slightly more ghosting this time as well.
      05-16-2010, 04:16 PM   #66
RBull
^ Good stuff!
