06-30-2023, 11:09 AM | #1 |
Rep 6
Z4MC Differential Oil
I am getting a Z4MC in a couple of weeks. I don't know the service history so I plan to change all the fluids. One issue I need help with is the differential fluid.
From what I read, I need to use gear oil that does not have any friction modifiers. The diff does not currently groan or click. OEM gear oil w/o FM is part no. 83-22-1-467-993. The problem is it looks like BMW discontinued the part and I cannot find any manufacturer that makes a substitute. The only thing I can find is gear oil with FM, part no. 83-22-2-282-583. My understanding is if I use a gear oil with FM, the LSD may click or groan if I ever use a gear oil w/o FM. Can anyone confirm if I am correct about the use of FM in the diff? Has anyone been able to find a diff oil without FM? If I can't get diff oil w/o FM anymore, I may just leave the old fluid in. Sorry if this topic has been beat to death, but I could not find anything recent. I only found old posts when gear oil without FM was still made. |
06-30-2023, 12:08 PM | #2 | |
Rep 12,565
https://www.fcpeuro.com/products/lim...fier-4oz-80301 I believe the ratio of FM to fluid is ~5% |
07-09-2023, 02:57 AM | #3 |
Rep 876
You can chose any 75W-140 oil as long as it contain LSD additives.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
07-09-2023, 05:19 AM | #4 |
Rep 781
This is what you want, https://www.ecstuning.com/b-castrol-.../001989520310/
As I understand it, the FM was needed for the break in period only.
2008 E86 M coupe
07-09-2023, 02:36 PM | #5 |
Rep 876
The FM was added because many people complained about the noise the diff would make driving around parking lots. The diff would make noise because the friction plates locked/unloaded during low speed tight cornering. The added FM makes the diff works less efficient during spirited/track driving, I would not use it.
