Go Back   ZPOST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      07-14-2021, 12:57 AM   #1
Coi
Drives: 21 X3 M40i, 07 Z4MR
California Smog Check Will Fail ECU Tunes Starting July 19, 2021
Any tune that's not from the factory or CARB-approved will cause your car to fail a smog check starting next Monday. Go to "Smog Check Results" on the BAR Smog FAQ then scroll down to "My vehicle failed a Smog Check for having modified software. What can I do?"
https://www.bar.ca.gov/Consumer/Smog...-check-results
Up until the 19th, smog on modern cars (2000 and up) used to include just a visual inspection and a OBDII check that looks for check engine lights and that basic emissions equipment was functional. There also had to be a certain number of miles driven since the codes were cleared or ECU was flashed (drive cycle) in order to pass. That meant aftermarket tunes, while technically not allowed, would not cause a problem if the rest of the emissions equipment is still stock. Under the new procedure, the OBDII check will fail a car that has a non-approved tune too. Some smog shops are already doing the new check.
As for how this system will work, over the last 10 years the state has created a database for what various ECU values should be in specific cars. Additionally, the Calibration Verification Number (also called checksum) will be compared against what it should be for that car from the manufacturer. Checksums for CARB-legal tunes are whitelisted. It is very difficult, but not impossible, to tune a car without changing the checksum. Any aftermarket tune will change the checksum unless it was designed specifically not to. https://tiremeetsroad.com/2021/07/13...led-smog-test/
I suspect this will be most relevant to N54 and N55 owners, because those cars have reached the age where they must be smogged and tunes are very popular. The earliest S55 and B58 cars will be reaching that age soon.
For many people this means that they will have to flash their car back to stock for at least one drive cycle before getting their smog check. It will be more of an issue for those with highly modified engines that may not run well or actually throw codes on a stock tune.
There are options for CARB-legal flashes, piggybacks, and engine parts for most BMWs but they often cost more than non-approved options. This new change in enforcement will likely make these offerings significantly more attractive.
In terms of shops who were already breaking the law and doing 'hot smogs', it remains to see if they will be able to get around this new system.
If we could please keep discussion completely off politics and have it focused on cars/BMWs I would appreciate it.
ried791.50
Telly9987175.50
      07-14-2021, 01:03 PM   #2
Coi
Some more articles on this:
https://www.roadandtrack.com/news/a3...g-smog-checks/
https://www.carbibles.com/california...ks-this-month/
Also as a bonus, a website for checking smog history of any car:
https://www.bar.ca.gov/services/Vehicle/PubTstQry.aspx
      07-14-2021, 01:32 PM   #3
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
good news, not a big deal for us S65 owners since our drive cycle takes fucking ages, but i recommend to stock to oem tune at least a month in advance to ensure you don't get flagged, so you get some miles on that drive cycle.
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
      07-17-2021, 11:46 AM   #4
ted99
Drives: former i3>330e, 528i>X5>530e
Looks like a CA resident that wants a "stop light grand prix" winner will need to go electric--or a Model S Plaid (lol) for a Canyon carver.
F32Fleet3571.50
      07-17-2021, 02:16 PM   #5
srybicki
Drives: 98 M3
Another reason to say bye bye to CA
Appreciate 7
ried791.50
Burnt C6257.50
Teutonic2709.00
Homerus36.00
      07-17-2021, 03:21 PM   #6
E92inNC
E92inNC's Avatar
1710
Drives: E92 335i
Add this to the list of reasons I'm glad I don't live in CA. A few day trip can be fun but I couldn't put up with that state full time
      07-17-2021, 05:37 PM   #7
Patton250
Patton250's Avatar
2940
Drives: BMW X3,M5,Turbo S
No doubt. These legislators are freaking nuts. at this point all I can do is laugh. It’s not like these residents are stuck there like the poor Cubans or North Koreans. I can’t believe anyone would live in that state at this point.
E92inNC1709.50
Homerus36.00
      07-17-2021, 07:52 PM   #8
cooolone2
cooolone2's Avatar
625
Drives: 20' M240iX B58, 01' 330XI E46
The right to repair includes programming. Base programming for an ECU doesn't mean it's the most efficient. It must account for and adjust for a variety of altitude, humidity, octane, etc. But a tune can be much more efficient... So a "tune" in itself is not indicative of any emission failure or bypass. It's very unfortunate, but hey, that's California, land of "live like we tell you!"
But those that live there elect these morons who enact these laws. So they have nobody to blame but themselves.
      07-17-2021, 09:11 PM   #9
FCX5
FCX5's Avatar
Drives: X5 50i
Higher quality of life and a better economy in CA compared to most of the other states in the US is probably what makes it a popular state. Highest GDP and highest GDP per capita among the big states. CA 'per capita' GDP is almost 50% higher than Florida for instance.
So the Cuba and North Korea analogy does not work for CA. Economically it is the most successful state.
Appreciate 8
chris7197334.00
19jdog86.50
5.M0NSTER3353.50
Xi-Xi37.00
MannyS357.00
540iSUP704.00
      07-17-2021, 10:51 PM   #10
learntocode
Drives: BMW
For performance/gains/HP+ is cool, but If your ECU tune is what makes the car sound crackle/gun shot pop/fart aloud, then YES.. you fail.
      07-17-2021, 11:11 PM   #11
chris719
Drives: '08 M Roadster
Blame the catless assholes and straight pipes crowd. If it wasn’t so obvious that people were getting around emission regulations then this wouldn’t have been done. You can smell those cars all over, and dieselgate further highlighted the role of software. CARB doesn’t care about your car making more power, it only cares about emissions.
      07-18-2021, 08:49 AM   #12
Wild Blue
Wild Blue's Avatar
Drives: 2021 X7 M50i, 2004 330i w/ZHP
That's California for you
Cross-continent road trip journal from BMW PCD to Alaska in new X7 M50i in this thread HERE!
New EVEN BIGGER road trip in X5 from BMW PCD to Alaska NOW ONGOING LIVE IN THIS THREAD!
Wilderness road trip journal to Eastern Alaska in this thread
And road trip journal to Denali and the Arctic Circle here in this thread!
      07-18-2021, 09:00 AM   #13
FCX5
FCX5's Avatar
Drives: X5 50i
Despite all that craziness a state that has managed to create an economy the size of Germany with half the population. Amazing what failure looks like. Right?
From what I can tell, fast growing regions like Austin, TX are more similar to CA in their local policies than their more 'traditional' state brethren areas…
Appreciate 8
pz6193278.50
chris7197334.00
19jdog86.50
540iSUP704.00
Xi-Xi37.00
      07-18-2021, 09:49 AM   #14
Wild Blue
Wild Blue's Avatar
Not sure what an economy has to do with a nanny state that regulates private life more than any other state in the union. Is smog checking ECU tunes supposed to prop up the economy? Out of respect for the OP, I'll leave it there.
ried791.50
________4158.50
      07-18-2021, 11:38 AM   #15
FCX5
FCX5's Avatar
Drives: X5 50i
A system works as a whole. Everything is connected. Some people care about climate, others don't. The least regulated states are also the poorest and have the lowest quality of life. So one needs to see the system as a whole. It is easy to just pick apart things in isolation. Plus, the regulation does not target tuning itself, it is looking at reducing pollution.
Also, I see a lot of people looking down on CA, the fact is that CA is one of the most successful by most measures. That is just a fact. Loved your road trip though…
Ah and the 'most American' cars (Model 3 and Y) are also made in CA. FWIW. As is the most valuable car company in the world….founded and built in CA. Bringing all this up since many here are in awe of Germany, but CA is just as impressive, if not more so. 😉
Appreciate 8
chris7197334.00
POBEP365.50
540iSUP704.00
Xi-Xi37.00
      07-18-2021, 08:47 PM   #16
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
On a new vehicle in California, the first smog test isn't required until the vehicle is 7 years old.
      07-19-2021, 10:22 AM   #17
jeff113
Drives: M2C, Focus RS
And has since moved to Texas due to dissatisfaction with CA...
ried791.50
ntg442888.50
heavyD^23688.50
      07-19-2021, 02:01 PM   #18
nodemgr
Drives: 2011 M3 ZCP Coupe 6MT
Which is ridiculous if they cared about the environment, they are ignoring a large percentage of the tuner community. People buy new cars, flash them/modify them, and sell them at up to 7 years, rinse/repeat.
Whether you agree or disagree with the laws, the laws that legislators write don't affect themselves on purpose. If they were, they wouldn't write them. The laws as written are to appease themselves, their families, and special interest groups/donors.
      07-19-2021, 02:11 PM   #19
ried
ried's Avatar
Drives: F31, F80
Virtue signaling nonsense. Just pissing in the wind while China pollutes more than all other industrialized nations combined.
ntg442888.50
Vivek.1367.50
540iSUP704.00
      07-20-2021, 01:44 PM   #20
chris719
Maybe you don't remember what LA smog was like in the 80s?
19jdog86.50
F32Fleet3571.50
jetrep16.50
      07-20-2021, 01:57 PM   #21
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Here's a classic! 1955
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
chris7197334.00
5.M0NSTER3353.50
540iSUP704.00
      07-20-2021, 02:05 PM   #22
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
LAX, 1980
chris7197334.00
5.M0NSTER3353.50
540iSUP704.00
Tags
california, ecu, ecu bmw tuning, n54, n55, piggyback, smog, smog check, tune, tuning
