      03-27-2019, 12:37 PM   #1
TK421BMW
Drives: BMW 328, X5, Z4
Aux for e85 Anywhere
Hi, trying to find (ideally) the ashtray Aux adapter for my e85. However, every site I can find says no longer sold, back order, etc.. Anyone seen these recently? Yes I've searched posts, but are all old and list sites that are no longer selling it. :P
____________________
Current:
2019 g05 X5 xDrive40i
2020 f30 440 xDrive Convertible
2004 e85 Z4 3.0
      03-27-2019, 05:59 PM   #2
KevinC
your average JAMF
KevinC's Avatar
BMW p/n 82110142174, looks to be unobtainium for quite some time now. I'd try finding any 2007+ Z4/Z4M at a wrecker and go that route. Should be on all cars from the factory as of 2007 (someone correct me if this is wrong - definitely true for Z4M).
'21 M2 Comp
'19 Golf R
      03-27-2019, 07:35 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Is the plain adapter still available? That's what I have.
You just need to poke a 0.25" hole in your location of choice.
Ashtray ... panel below heater controls ...
Mine just dangles behind the head unit and is connected to a vent mount dock with a standard patch cable.
      03-27-2019, 11:35 PM   #4
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
i found a bunch of them, but none for the ashtray install. those disappeared, i installed mine couple of years ago. good luck w/search!
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      03-29-2019, 09:21 AM   #5
Ponta
Ponta's Avatar
17
Drives: Z4 3.0si roadster
AUX problem
I have a problem with AUX connection, radio does not show AUX option after I push MODE button. It doesn't recognise that the wiere is there.
My car (no navi) 03/2006:
S662A Radio BMW Business CD
S672A CD Changer For 6 CDs
S676A HiFi Speaker System
I have an empty space behind the radio in lower right corner, there is no switch there so I do as follows:
      03-29-2019, 12:44 PM   #6
Clearancediver
Drives: 2004 Z4
When I bought my simple Chinese knock off plug on adapter.... they were very specific as to where to plug in and it's orientation. It might be that your plug isn't oriented right.
Sent from my smart phone...
      03-30-2019, 02:50 AM   #7
Ponta
Ponta's Avatar
17
Triangle on top defines that this is top
      03-30-2019, 08:44 AM   #8
Eau_Rouge111
Eau_Rouge111's Avatar
Drives: 2009 128i and 2007 Z4M Coupe
Try turnermotorsport.com...that's where I ordered mine from. But this was 2 years ago.
      03-30-2019, 04:25 PM   #9
Lakespeed
Lakespeed's Avatar
Drives: 2011 e93
Turner no longer carries them. I agree with earlier post as to order cable from turner and drill hole in ash tray.
      03-31-2019, 12:45 AM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by Ponta View Post
I have a problem with AUX connection ...
I've looked at your setup and as far as I can tell you have it correct.
Where did you get this kit?
The stock mod has a nodule in the middle of the cable that's an equalizer or impedance matcher.
I think that's how it can tell if the Aux is present.
Does yours have something that looks like a couple of resistors and a couple of capacitors?
As an aside to add to the knowledge base, when it's over 100°F in my car it won't stay on Aux.
After 10-15 seconds it switches to AM. Once thing cool off it's fine.
      08-16-2019, 01:20 AM   #11
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
here you go:
https://www.ecstuning.com/b-genuine-...e/84110302893/
84110302893
That cable is used in a bunch of different models, so it shouldn't be discontinued any time soon. drill a 1/4" hole in the panel under your center console and pop that through, it is a panel mount aux connector so you mount it anywhere.
For the wiring, just pop the pins out of that black connector and then pop them in to the (same) black connector in the same spots that is already behind your radio.
This version actually looks a lot cleaner after the install than the factory version in the 07s and 08s.
      07-16-2023, 09:27 AM   #12
Lucky1
Drives: '08 128i Coupe SGM 6MT
Anyone know where to get one in 2023?
Most online parts stores list as discontinued.
There was a website for a wrecker out of CA I think which inventoried all parts from tons of German wrecked cars. Maybe I'll look for it there.
      07-16-2023, 01:44 PM   #13
zed_fan
Drives: 2006 Z4MR, E60 M5 6MT
https://www.fcpeuro.com/products/bmw...on-65120153502
This aux cable would work and is still available.
