      05-29-2018, 10:11 PM   #1
d30si
Drives: 2006 z4 3.0 si
Need advise on wheels and tires
HI guys I need your advise thru experience has anyone have try the 19x10 on your Z? I have a 07 z4 coupe and I’m thinking of replacing my 18’s stock rims and change it to 19’s.
19x8.5 front and 19x10 rear not sure what offset If someone have done these what offset did you use to make a perfect fit.
On my other Z roadsters I’m running on 19x8.5 and 19x9.5 et35 36
Not sure on the 19x10....
Thanks for looking
Edit my bad got mixed up with my other car set up off set is 45mm all around...
      05-30-2018, 03:10 PM   #2
coh661
Drives: 2007 Z4M Coupe
2007 Z4 M COUPE  [8.00]
I'm running HRE FF01 Tarmac Black with Michelin Pilot Super Sport tires (19 x 8.5 ET 30, 225/35/19) (19 x 10 ET25 after 15 mm spacer, 265/30/19)
H&R coilover suspension lowered about 1.5" with no rub
      05-30-2018, 06:27 PM   #3
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
not so sure 10's work on a non-///M.
typical fitment is 9.5et45. I see you're used to et35, though that's probably more than flush to the fender.
      05-30-2018, 08:12 PM   #4
coh661
Sorry didn't realize you were referring to non-M fitment
      06-02-2018, 01:41 AM   #5
d30si
My roadsters
      06-02-2018, 12:58 PM   #6
3002 tii
3002 tii's Avatar
2288
Max I’d go is 9.5 et35 in rear and you’d probably need some negative camber. Any wider and you’ll need an undersized stretches tire and/or roll fenders.
Follow for latest mods
