      12-21-2007, 10:40 PM   #1
jmillet
jmillet's Avatar
64
Radiator cover hole plate
I got tired of looking at that useless hole in the radiator cover so have been looking for some way to cover the hole. I went browsing at Home Depot and came across some matte black material (Wilsonart SKU 1595-60 http://samples.wilsonart.com/p-289-black-1595-60.aspx) that looked like it would be a good match for the black plastic cover. It turns out to be a perfect match. I then made a paper pattern and, using multipurpose shop scissors http://www.harborfreight.com/cpi/cta...emnumber=36872
cut out a piece of matte black laminate large enough to cover the hole when affixed from underneath the cover.
Removing the cover involves destroying eight expanding plastic rivets, P/N 51 16 8 197 908, at 30 cents each MSRP. I got a bargain from my dealer and only paid $1.08 each with a BMW Club discount
I used Permatex black silicone adhesive to secure the plate and then applied aluminum HVAC tape.
Name:  Radiator cover with hole plug.JPG
Name:  Hole cover top.JPG
Name:  Hole cover underside.JPG
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      12-22-2007, 10:21 PM   #2
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
307
Drives: '07 M Coupé & '16 435xi GCoupé
Cool. I like your new cupholder!
      12-22-2007, 11:24 PM   #3
F360C
Drives: E86 S54
Look Great! I have been wanting to do this for awhile. Although I don't know why you had to destroy the plastic rivets???? I have had that cover off at least five times and I am still using the same rivets..... they are very easy to take out with out destroying them
07 Z4 M Coupe AW/IR
      12-23-2007, 01:06 AM   #4
epbrown
epbrown's Avatar
Didn't Ron do this a while back? He made some sort of custom whominahominathingumjig, iirc.
      12-23-2007, 01:19 AM   #5
jmillet
jmillet's Avatar
64
Silicone lubricant
I can't explain why these expanding rivets were so hard to remove but after rounding off the screw slots on a couple of them I finally decided to simply cut them off and install fresh rivets. I sprayed silicone on the new rivets so they should be much easier to remove.
Installed a cover today and the plastic expanding rivets were removed and replaced without incident. The secret is using the correct tool. On first glance the screw head looks to be Phillips, but upon closer examination I discovered them to be square female.
The new rivets I installed were phillips head. The moral of the story is examine the rivets carefully and use the appropriate driver.
Jim Millet
      12-23-2007, 01:47 AM   #6
jmillet
jmillet's Avatar
64
Ron's gizmo too complicated
I considered Ron Stygar's solution but determined it to be too complicated and expensive for my taste.
http://www.bimmerfest.com/forums/sho...d.php?t=194541
My version including the expanding rivets cost me about $15 and it looks like BMW made it that way.
Jim Millet
      12-23-2007, 09:35 AM   #7
Starscream
Starscream's Avatar
what BMW roundel fits where you have placed yours?
Is it the same size as the hood or the trunk?
Imola Red Roadster
      12-23-2007, 02:41 PM   #8
jmillet
jmillet's Avatar
64
E46 and E90 trunk lid emblem
It is P/N 51 14 8 219 237, MSRP $33.00.
This emblem has three posts on the backside so you can either drill holes in the radiator cover and secure the emblem like Ron Stygar did http://www.bimmerfest.com/forums/sho...d.php?t=160551
or, if you're lazy like me, simply cut off the posts and secure the emblem to the radiator cover with Permatex black silicone adhesive.
Jim Millet
      12-23-2007, 03:37 PM   #9
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
My head doesn't end up under the hood enough...
Best Website EVER!
      12-23-2007, 03:41 PM   #10
Starscream
Starscream's Avatar
Thanks!
The hole doesn't really bother me that much,
However I do have a powdercoating gun and oven so If I really wanted to do the whole crinkle finish blah blah I might try that when It gets even colder up here and I'm stuck for things to do to my M
Imola Red Roadster
      12-23-2007, 08:29 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Did this last year but I bonded the filler piece on the top side.
      12-24-2007, 12:35 AM   #12
epbrown
epbrown's Avatar
Doesn't BMW sell a fancy metal overlay for that area with the roundel etched in?
Edit: found it! Bit different than I remember...
      02-06-2008, 07:04 PM   #13
gokartmozart
gokartmozart's Avatar
Drives: 2008 Z4 M Coupe, & 2003 Z4 3.0
I think is chromed plastic, very disappointing for those who ordered one. Correct me if I am wrong on this one. I haven't actually seen one.
2008 Z4 M Coupe (Alpine White / Imola Red / Carbon Leather trim)
2005 530i (wife's DD)
2003 Z4 3.0 6sp (college son's hand-me-down)
      02-17-2017, 01:21 PM   #14
jlkansascity
Drives: 2003 325
cheap plastic rivets Glad I found this post
I'm glad I found this post I have been looking for those rivets but couldn't find the part number. I was looking for info on convertible top motor replacement and wandered across this post.
BMW of Alexandria does a lot of internet business and has these rivets for .39 which makes them a lot more palatable.
http://parts.bmwofalexandria.com/pro...%252d908).html
Gotta save as much $$$ as I can for the convertible top motor LOL
