      12-12-2008, 05:51 PM   #1
sirmalloc
code monkey
sirmalloc's Avatar
Drives: 2006 Z4M Roadster Imola/Imola
Exclamation SES light and limp mode
I was out driving tonight and my SES light came on and the engine feels like it went into limp mode - very choppy, like it's only running on 3 cylinders. I kept the revs down and drove it home. Since it's the weekend my dealer can't see me until Monday. Without having a code scanner, does anyone know what typically causes this? My last fillup was about 65 miles ago, 93 octane...I would think if it's the gas I would have noticed it sooner.
I've turned the car off and started it again a few times and the light is either there when the car is started, or returns within about 10 seconds. Is there any easy way to do a reset of the ECU and see if it returns? Anyone else had this happen?
      12-13-2008, 05:47 AM   #2
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
Why would you want to reset the light if your car is obviously not running properly. The light isn't the problem; the light is an indicator that a problem exists.
      12-13-2008, 09:41 AM   #3
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Sounds like a misfire, take it to the dealer and have them check it for codes. Once the figure out what cylinder is the problem have 'em check the coil packs/spark plugs.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      12-13-2008, 03:01 PM   #4
sirmalloc
code monkey
sirmalloc's Avatar
Thanks....that seems to be the most common response I've found searching around for others having this issue. My friend is bringing over his OBD-II scanner tomorrow to check the codes...would a misfire show up on a generic OBD-II scan?
I think this is what torture feels like. Driving the M for 7 days and then having to go a whole weekend without being able to touch it.
      12-14-2008, 01:23 PM   #5
ATX750i
ATX750i's Avatar
Drives: 2009 Honda Civic Si
2003 Z4 2.5i  [0.00]
Misfire codes should show up on a generic OBD-II scan.
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD
09' 2.0 Polished Metal Metallic Honda Civic Si - Current
      12-15-2008, 08:41 AM   #6
sirmalloc
code monkey
sirmalloc's Avatar
Took it to the dealer this morning and was out in less than 2 hours, including a wash. Turned out to be a bad coil pack on one of the cylinders. Glad this turned up now and not on the 1200 mile roadtrip I'm about to take over Christmas.
