      06-09-2023, 11:49 PM   #1
gkgsvensson
gkgsvensson's Avatar
75
Drives: 2007 Z4 M Coupe
Turner Monoball FCABs on Z4M
Hi all, I just got done installing turner monoball FCABs (the lollipop bushings) on my z4m coupe. Of course, these reduce caster slightly in exchange for a tighter steering feel. However, I’m noticing some kind of binding noise coming from the passenger side after install and was wondering if anyone else running these have noticed/resolved this problem as well. They otherwise feel great.
2001 E39 M5 - Titanium Silver
2007 Z4 M Coupe - Sepang Bronze
2008 E92 M3 - Jerez Black
      06-10-2023, 06:09 AM   #2
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Just spitballing here, your wishbones look like they are original so maybe the 2 ball joints are slightly worn out and because the new lollipop bushings aren't offset, they are holding the ball joints in a different position and causing noise.
You did reinstall the reinforcement plate before driving the car right?
2008 E86 M coupe
      06-10-2023, 10:00 AM   #3
gkgsvensson
75
The arms are new since a year ago so I’m hoping it’s not the ball joints.
I did reinstall the plate and I suspect the wishbone is possibly colliding with it in some way and I need to realign it
      06-10-2023, 10:44 AM   #4
maupineda
Drives: E86 Z4MC
I played with the idea just to find out that many of the people having them on E46 M3 disliked them due to noises. You will be better off installing stock new ones
      06-10-2023, 11:53 AM   #5
rsutoratosu
Drives: Z4 3.0i
I actually woke up dreaming about them 2 days ago.. good thing I didn't pull the trigger. Thanks!
-Roranji
      06-10-2023, 11:59 AM   #6
gkgsvensson
75
Ok I confirmed there is no collision with the plate. It seems like the bushing itself is binding and so I’ve requested a replacement. Will update when I try it on. I’m really hoping these work out
      06-11-2023, 06:44 PM   #7
cbpip
cbpip's Avatar
151
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Go with Rouge engineering FCAB, far better and no NVH or other issues. They are very solid pieces .
https://www.rogueengineering.com/Rog...-20_p_100.html
      06-16-2023, 07:06 PM   #8
gkgsvensson
75
I just put my OEMs back, much better. Lesson learned, even without the creaking I didn’t like how they felt. The loss of caster made the steering too light and I never felt any more feel
