      05-15-2012, 08:42 PM   #23
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
awesome. Mine should be here in a few days too. I'll install them together with my turner 90mm stud kit
      05-18-2012, 02:54 AM   #24
aljoy12
Drives: 335i e90
i have a volk progressive ME on 19s and the bore size is 73.1mm so will i need hubcentric rings for it to make it fit for bmw bore size which is 72.56?
      05-18-2012, 02:57 AM   #25
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
With that small of a wiggle room, I'd bypass a hub ring and run the wheels as-is first. If your tires are good and alignment is good, but you get wheel vibration, then get hub rings.
      05-18-2012, 06:49 AM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes, you will need rings.
I had Volk prog. ME on my old roadster & had vibration w/o rings.
      05-18-2012, 09:58 AM   #27
mfanatic325
///M-fanatic
Taiwan
193
Very surprising!
      05-18-2012, 10:47 AM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
+1 I was surprised too.
      05-18-2012, 11:21 AM   #29
aljoy12
Drives: 335i e90
where can i get them? and what size? plastic ones dont work i think so i will get the aluminum ones
      05-18-2012, 04:16 PM   #30
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The link in the 1st post
....or
http://www.ebay.com/itm/HUB-CENTRIC-...-/380319042007
      05-18-2012, 05:07 PM   #31
aljoy12
Drives: 335i e90
i think that should be it! thanks!
      05-18-2012, 05:57 PM   #32
aljoy12
Drives: 335i e90
the tires are brand new and i just got them aligned so the vibration was decreased but i think the hub rings is the key so i already ordered the 73.1-72.56 hub rings.. hope it will work!
      06-27-2018, 11:43 AM   #33
Prazision
Drives: 2011 BMW 328xi Wagon
not to bring up an old post, reached out to Mackin Industries, they mentioned we would need 74mm - 72.56, and not 75mm - 72.56. Can anyone confirm?
