      06-29-2020, 03:37 PM   #1
lrz
Drives: BMW Z4M
///M stock LSD upgrade to 3.91
Hello,
I want to upgrade my stock differential to 3.91.
What parts do I need for the upgrade?
This will be enough?
https://www.ecstuning.com/b-genuine-...net&utm_term=1
      06-29-2020, 07:22 PM   #2
rueyme
Drives: red z4
yes i am doing the same as well. where are you located?
      06-29-2020, 08:58 PM   #3
maupineda
Drives: E86 Z4MC
I think you may want to replace bearings and seals.
Racing diffs have some very attractive kits which include the clutch packs
      06-30-2020, 10:02 AM   #4
lrz
Drives: BMW Z4M
Thank you very much for your answers.
Unfortunately, I'm not located in the US.
      06-30-2020, 10:24 AM   #5
GuidoK
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
there is probably a crimp bushing between the outer inputshaftbearing and inner inputshaftbearing.
That bushing has to be replaced too, to set the correct clearance.
If not, it's (bearings on the inputshaft that is) shimmed and you need both shims and a special tool to measure the size of the shims you need.
That would look something like this:
and new seals of cours.
Mind you, this is not an easy swap. Don't attempt this if you dont have experience with differentials. To make it worse... there is no data about settings (backlash etc) and you need a very special fricton meter tool to monitor the force it takes to rotate the input shaft to set the pretention on the bearings:
      07-02-2020, 02:56 PM   #6
lrz
Drives: BMW Z4M
Thanks for your great help!
      07-20-2020, 05:01 PM   #7
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
People a lot smarter at building cars than I am have cautioned against DIY-ing this. It will become a HUGE regret unless you have a LOT of experience or get super lucky. It's cheaper yes ..........in the beginning.
      07-24-2020, 06:10 AM   #8
1zpower7
Drives: BMW Z4
This job is for the pros....
