      06-26-2020, 11:30 AM   #1
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
horrible noise at stop
So I have a horrible noise when the car is stopped and the clutch is not pressed. It sounds like the whole car is about to fall apart. No engine codes related to this either.
I'm going to be taking the car to a HPDE this weekend. After that, I'm going to start looking at dropping the transmission and replacing the clutch. I'm wanting to go with a lightweight flywheel and some kind of better clutch. Thinking about replacing the input shaft bearing while I have it all torn apart as well.
I'm leaning toward the input shaft bearing, but I want to get confirmation.
Z4 3.0i 2005 6 speed
      06-26-2020, 01:43 PM   #2
No_Dominion_2
AKA No_Dominion
No_Dominion_2's Avatar
Drives: 2007 Z4M
Unless they let you self-tech prior to the event, I can't imagine any club/group signing off on your car running the track if it's making that disturbing of a sound... Either way, I wouldn't risk it.
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune
Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces
H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals
      06-26-2020, 07:14 PM   #3
Alaberti
And yet
Alaberti's Avatar
Drives: Jaguar F-Type V6 S BDE
Get an ODBII reader, might be an ignition coil
      06-27-2020, 09:18 AM   #4
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
SMF will sound even worse.. kinda like a Duke.
      06-28-2020, 12:17 AM   #5
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
Mileage? where is the noise coming from? when does the noise occur and when does it stop occurring? any additional symptoms? vibrations?
      07-01-2020, 01:54 PM   #6
Yapakanichi
Monkey Marshall
635
Successfully made it through the weekend. The sound completely stops when I press the clutch in. I'm going to get a new clutch and flywheel and replace the input shaft bearing while the transmission is out.
