      03-13-2014, 06:23 AM   #23
lsz4
Drives: Z4 6.0
Originally Posted by 2skiddy View Post
Hi, What a great project, I wanted to do one years back, but knew there was a lot of fabricating to do to get the body to sit correctly with suspension etc. Fantastic looking car always, the GTR. As for suspension, have you thought of Intrax, would a set from an E46 M3 maybe fit, although the front arms and hubs would need to be swapped over. Not sure if Studie in Japan went that route, maybe worth asking? How did you find the quality of the bodykit, as I know of someone over here in the UK after one?
Cheers
Hi unless your prepared to modify everything I wouldn't recommend using the gtr kit from flossmann, Don't expect it to be OEM quality as far as aftermarket kits go the quality is really good fitment is fairly good but there is a lot of fabrication to mount the front bar also a heap of finishing to bring it up to a paintable standard. the main issue is the wheel gap this kit is designed for monocock or tube frames where the car is 60mm off the deck its just not possible to get it low enough with the standard suspension without stuffing the roll centre.
If you like the kit but want to keep you suspension usable I recommend
http://www.carbon-goeke.de
Kit has extra material in the wheel arch and the quality of his work looks better than flossmann from the photos he sent me, also his kit bolts up to your standard mounting points. The guy from goeke can't recall his name was really helpful answered all emails no problem I'll defiantly use him after I plough this into a wall.
As far as the suspension goes Cusco were full of shit those guys couldn't organise their underwear draw. I now have ohlins in the UK building me a set of 3 way adjustable mcphersons
      03-13-2014, 07:54 AM   #24
Psychodo
Psychodo's Avatar
Drives: 2013 Boxster S
Whoa...that is going to look awesome !
      03-14-2014, 03:37 PM   #25
2skiddy
Drives: Z4M Coupe
Hi, You are spot on with the bodykit not fitting the standard chassis. I did my homework early on and realised that the kit won't fit unless major body shell fabrication is carried out. Looks like you are well on the way to making it all work correctly, which is great, otherwise it kind of looks wrong. When I had my Z4MC GT4 track car, I really wanted the GTR look as it was narrow bodied, but the more I delved into it the more I knew it would result in a total rebuild, so took the plunge with a factory VLN GTR shell and carbon body, and sold the GT4 car. This has saved a lot of fabrication time although there is still a lot to do as none of the series suspension will fit due to the bespoke construction. Mine will be a 2 year project, I hope your's will be done sooner.
Cheers
      04-17-2014, 03:58 AM   #26
2skiddy
Drives: Z4M Coupe
Hi lsz4, Any more progress, I love ambitious projects!
Cheers
      05-19-2014, 09:09 PM   #27
v8z4
Drives: 2003 Z4 roadster
Looks like his might be done before mine. Here's my update:
The motor is mounted (Motor plates are in, welded, and I have test fit all of the accessories). I have started laying out the wiring to make the wiring harness, but don't want to spend $500 on injectors yet so I'm focusing on building rather than buying right now. I'm currently in the process of building tubular front lower controls arms (driver's side is done, need to build the passenger's) so I can get the 1-7/8" headers finished. Progress has been slowed, but I will perverse! lol
Front plate:
Mid plate:
Overall:
Front control arm bushing replacement (3/4" rod end threaded into milled steel block):
Porsche 996 calipers, CSL rotors, and tubular control arm:
Front tubular control arm:
Chris
      05-20-2014, 12:25 AM   #28
Woots
Woots's Avatar
Drives: Z4///M Roadster
Awesome!!
      05-20-2014, 06:42 PM   #29
jra
Drives: 2005 z4
Nice!
      05-20-2014, 07:11 PM   #30
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Looking pretty sick!
      05-21-2014, 05:04 AM   #31
lsz4
Drives: Z4 6.0
progress
v8z4 can defiantly appreciate the work, its not as easy as some would think
different solution to the front engine mounts also.
I am more or less done have 2 more plates to make for drivers footwell and trunk floor. remove motor, start paint process bout 2 weeks solid work if we can find the time. haven't touched it for last 5-6 weeks
      05-21-2014, 08:06 AM   #32
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
You installed the steering wheel on the wrong side!
But really, really great work. Can't wait to hear these bad boys fired up!!!
      05-21-2014, 10:20 AM   #33
v8z4
hehe, might want to fix the steering wheel location before you get too far along
How did you do your trans mount (do you have a good shot of the mount in the car)? Is your shifter mounted to the tunnel or the trans? If mounted to the tunnel, what trans are you using?
I see what looks like a small surge take for the fuel system. Are you using the factory pump to pump out of the fuel tank (to the surge tank) and then an external pump to pull from the surge tank to the engine?
Chris
      05-21-2014, 01:50 PM   #34
lsz4
Drives: Z4 6.0
Trans is 6 speed t56 with ripshift race shifter is mounted to both the trans and trans tunnel. Fuel cell is JAZ item and now located in the trunk, small pump feeds surge tank single bosch 044 feeds the engine.
      05-21-2014, 04:00 PM   #35
v8z4
Wait, what? You can't hard mount the shifter to both the trans and the tunnel, you will snap something (likely the tail shaft housing).
Chris
      05-21-2014, 04:13 PM   #36
lsz4
Drives: Z4 6.0
Mount to tunnel floats inside rubber boot it's not solid
      05-21-2014, 04:15 PM   #37
v8z4
Oh okay, that makes more sense. Is your engine/trans on poly or solid mounts?
Chris
      05-21-2014, 05:10 PM   #38
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
awesome!!
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      05-24-2014, 02:44 AM   #39
lsz4
Drives: Z4 6.0
I used the standard rubber mounts from the donor car and fabricated new brackets to pick them up on the engine and body also had to remove a big piece of the tunnel to get the trans in though.
      05-24-2014, 02:48 AM   #40
v8z4
Did you cut the firewall to move your motor back? I didn't have to modify the tunnel at all to get my trans in so I'm curious what the difference is.
Chris
      12-13-2015, 01:36 AM   #41
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
wow.. hanging on for more updates...
Powered by
      12-13-2015, 02:59 PM   #42
deemo319
deemo319's Avatar
Drives: BMW
Cheers
The guy at Goeke Carbon is Jens. He is good people and knows his stuff!
      12-14-2015, 03:53 AM   #43
2skiddy
Drives: Z4M Coupe
Yes, would be great to see some progress on this ambitious project.
      01-13-2016, 05:29 AM   #44
lsz4
Drives: Z4 6.0
Update
Quick update majority completed about 6 months ago, just fine tuning now and the all important livery to go. Have only had it on the track twice as have been too busy, this year will see it get plenty of use.
