02-03-2016, 02:01 PM | #45 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
They don't have them listed on their site for z4s , do either of you know if they still produce them?
02-03-2016, 03:21 PM | #46 |
Rep 5,329
think I'm one of the minority thats very happy with the stock change, hell even the stock gear lever , lmao!
02-03-2016, 03:57 PM | #47 | |
Rep 11,667
If you contact them, I'm sure they will do a one off. (not cheap though) Its been long enough, maybe there's interest in another GB here.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 02-03-2016 at 04:09 PM.. |
02-09-2016, 04:07 AM | #50 |
Rep 503
Drives: Z4 M Coupe
You'd see some improvement with a short shift kit mate. I think it's worth it.
02-09-2016, 04:55 AM | #51 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
Right now I'm tossed up between the RE kit or this. RE kit is immediately available and not as pricey, however I do not doubt the AS ssk would be a better choice
02-09-2016, 06:34 AM | #52 | |
Rep 12,565
Although if you go AS its so notchy you'll need to change to a taller knob Last edited by 3002 tii; 02-09-2016 at 07:07 AM.. |
02-09-2016, 07:29 AM | #53 |
Rep 5,329
exactly my problem with SSKs they make the shift either heavier or add alot of notchyness to the shift quality...
02-09-2016, 03:26 PM | #55 |
M = Midlife Crisis
65
Rep 2,006
I put the stock knob back on after the install. Works for me.
2006 Z4MC - #LL93158
02-10-2016, 12:43 PM | #56 |
Rep 195
Does anybody still have one they need to install? I installed mine ~6 months ago (with help from this thread) and thought about adding my installation tips. I figured I may have been the last one to install the shifter from the final group buy though.
02-10-2016, 12:56 PM | #57 |
Rep 11,667
^ I know someone who has yet to install.
I think he was planning to get to it this spring.
04-24-2016, 10:22 PM | #58 |
Rep 632
Unless he has made any changes to how he is manufacturing these, there are a few tiny little mods/tricks you can make to the AS kit during installation that will take ALL notchiness out of it. As I recall I discussed what I did in my original posts but honestly, I haven't read through it again (I'm really friggin long winded!....) Mine ended up not notchiness at all and also took out all the slop of the original, which I am very familiar with having had an E46 M3 before this. If you think you are happy with the original that is great but truly, you really can't imagine just how much better it can be.
04-12-2017, 07:53 PM | #59 |
salty cowboys fan
6159
Rep 3,408
Great write up, will be going through this on the weekend. I have to remove my diff anyway, so I'm thinking I might as well remove the driveshaft to hopefully make things a bit easier. That clip doesn't sound fun
For anybody curious, Ronald is still making these. Got mine within a week of ordering, custom spec, and around GB price ($350 + shipping?) |
04-13-2017, 10:32 AM | #60 |
Rep 195
More tips:
1. Take a curved pick tool and use it to hook over the old clip & yank it out. I can't remember if I read this somewhere or thought of it myself, but it made the process much easier. 2. Assemble the AS shifter outside of the car and rotate the bushings a few times. The tolerances are so tight that it can be hard to install the first few times. If you slip it on & off a few times outside of the car, it's much easier to do the final install. |
04-13-2017, 10:48 AM | #61 |
Rep 131
Drives: 07 Z4 M Coupe
Sounds like a few of you have AS kits on order, I talked to Ronald this morning about a kit for my Z4MC, might have to pull the trigger on this soon...
04-18-2017, 06:47 PM | #62 |
salty cowboys fan
6159
Rep 3,408
Went through this earlier today. Thanks again for the guide. Check out the room you get when the drive shaft is removed that round clip is no sweat when you have space
shes home! '22 M4 Comp xDrive
04-19-2017, 03:06 PM | #63 |
Rep 11,667
FWIW...
anyone removing the drive shaft should inspect & replace the guibo at the same time. If you have a few miles on the clock... just replace. Also, check the rear CV joint, it should be repacked. (use CV grease) When repacking its a good idea to fill the flange on the front of the diff. with grease, it helps keep the grease in the CV joint.
yousefnjr6159.00 |
04-19-2017, 04:46 PM | #64 | |
salty cowboys fan
6159
Rep 3,408
Guibo - 26112226527 Driveshaft CV Gasket - 26111229503
inTgr8r2431.50 |
07-12-2017, 02:08 PM | #66 |
Rep 632
Whew, major thread revival. I'll have to see if I can locate the photos. It's been a loooong time since I posted this, or since I've been around here. The addition of kids, a boat restoration project, one thing after another and I haven't focused on the car much. Shoot, it's embarrasing as hell, car only got 500 miles on it last year.....but it seems the low mileage versions are a bit of an appreciating or at least status quo investment. I'll look into the photos, redo what I can.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
