05-28-2020, 12:51 PM | #1 |
Rep 154
Code P2414 on Z4M?
Hi all,
My Z4M started idling a little rough recently, finally got a CEL, code P2414. Some quick research indicates that it is probably an oxygen sensor. Any ideas a on which ones I should start replacing? Thanks!
2006 Z4MR
2016 Tacoma Off-road Tampa Bay, FL |
05-28-2020, 03:19 PM | #3 |
Rep 154
Thanks, not a bad idea. Can you confirm there are 2 sensors for cylinders 1-3 and 2 for cylinders 4-6? Total of 4 precat sensors to replace? You think Bosch is acceptable replacement vs BMW oem? They seem to be about half the price.
05-28-2020, 10:25 PM | #4 | |
Rep 264
2 on main cats: https://www.realoem.com/bmw/enUS/sho...diagId=18_0658 and 4 on pre-cats: https://www.realoem.com/bmw/enUS/sho...diagId=18_0664 But pelican parts article talks about 4 on pre-cats only: https://www.pelicanparts.com/techart...eplacement.htm And folks in the UK say those that fail the most are on pre-cat: https://z4-forum.com/forum/viewtopic.php?t=12406 Also if you've not seen this yet https://www.zpost.com/forums/showthread.php?t=1459357 PS: sorry, can't recommend the brand. mine are still stock... knocking on wood... |
05-29-2020, 12:38 PM | #5 |
Rep 2,867
My understanding is that there are only 4 sensors in US cars. 2 lambda sensors in front of the main cats and 2 oxygen sensors after the main cats. The secondary cats are unmonitored. The main cats are built into the headers. The oxygen sensors in the secondary cats are for Euro cars since there are no cats built into Euro headers
05-29-2020, 12:53 PM | #6 |
dances with roads
4732
Rep 4,096
When I did the clutch I took the entire exhaust off my car, from the back of the headers to the tip of the tailpipes. No oxygen sensors on anything back there.
