      09-06-2019, 08:46 PM   #1
eggman51
Drives: 2006 BMW Z4 M Roadster
Parts required for Evolve CSL Airbox install?
Hey Folks,
I got a great deal on an Evolve CSL airbox in near new condition. My indy will do the install, and I will get a tune from Randy at Epic Motorsports.
I usually provide the parts, so I wanted to confirm this list of parts to install a CSL airbox from Evolve:
CSL Airbox Air Shut Off Valve
BMW # 11617833647
CSL Crankcase Vent Hose
BMW # 11157833649
IAT Relocation Kit
BMW # NA
OPTIONAL (but I am going to do it this way):
CSL Dipstick Tube
BMW # 11437833653
CSL Oil Dipstick
BMW # 11437834784
I have the 6 x rubber thingys for the trumpets, and the 12 clamps for those. I will also clean the air filter prior to installation.
Am I missing anything?
Cheers,
Eamonn aka eggman
      09-07-2019, 01:30 PM   #2
sirhodjibob
Drives: 99 Carrera, 99 M3. Sold: Z4MR
You can skip the CSL dipstick. You'll have to remove the airbox every time you want to check the oil level with it. Just keep the factory one and turn it about 180 degrees. It'll make more sense when you're doing the install. I got new intake mounts (11617830735) and went with OEM hose clamps vs the Evolve supplied ones on the engine side (cleaner look in my opinion). I also went with the Eventuri scoop to help direct more air towards the airbox opening.
Here are the links I used for guidance on my install:
https://www.zpost.com/forums/showpos...0&postcount=22
https://www.zpost.com/forums/showthread.php?t=1148282
http://www.m3forum.net/m3forum/showthread.php?t=393558
Enjoy it. The sound is incredible, but be warned it becomes incredibly hard to keep your foot out of it when driving.
      09-07-2019, 05:15 PM   #3
eggman51
Thank you so much for a helpful post. I didn't realize the CSL dipstick would reuqire airbox removal to check oil levels vs simply rotating the stock Z4M one. I was trying to "do it right", but this seems like a hassle. Saves some considerable money too - much appreciated!
Regards the BMW #13621739510 - Intake Air Temperature Sensor; is this needed if also purchasing the Turner IAT relocation kit?
Thanks again - very excited to get these parts together and get this installed - love the sound of the CSL S54, it's one of the main reasons I bought the car.
Cheers,
Eamonn
      09-07-2019, 06:40 PM   #4
sirhodjibob
You can use the IAT sensor that comes with relocation kit. I believe it's the same as the one on an E38 7 series and used on a few other models. Just make sure your tuner knows which IAT sensor you are using so they can apply the proper scaling.
      09-08-2019, 10:10 PM   #5
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
You don't really need the vacuum hose either, as you can furbish your own from the old vacuum hose, you just need a longer bit of hose. (Fuel hose works a treat)
Same with the iat relocation kit, you can solder up your own, or you can just buy the one you listed.
Not sure about the evolve box, but the carbonious box needed the bigger trottle body hoses.
If you can put the iat probe wherever you like (can't on Karbonious), put it as far away from the engine as possible.
      09-09-2019, 12:34 AM   #6
eggman51
Thanks!
I bought the parts so I can have the original stuff available in case I decide to revert.
Will be a bit before I get it done. Hoping to do dyno tests in between some of the updates, will see if I can manage to pull that off.
Thanks again for all the help!
Cheers,
Eamonn
      10-15-2019, 06:01 PM   #7
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Cheers,
Eamonn
Turner IAT relocation kit comes with sensor as I recall. It is the same sensor Evolve provide.
eggman51198.50
      10-15-2019, 08:37 PM   #8
eggman51
TYVM!
      02-16-2020, 10:40 AM   #9
saintex
Drives: Z4MC BSM E92 335xDrive BSM
evolve
Hey Eggman did you install your intake and get it tuned by Randy?
any pre/post dynos?
      02-16-2020, 02:02 PM   #10
eggman51
Booked into the shop week of Feb 24 to have the airbox, exhaust and tune installed.
I have a pre-dyno, and will do a post dyno sometime in March.
      02-18-2020, 12:04 AM   #11
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sweet!!!
Powered by
