Go Back   ZPOST > Marketplace > Sponsors Classifieds
      09-30-2014, 02:19 PM   #1
Race Precision Motorsport
Race Precision Motorsport's Avatar
16
Drives: F80 M3
RPM▝▚▖ BREMBO GT super sale!
Stopping power through heat dissipation is the single greatest advantage in a quality braking system. The factory brakes are great for the average consumer but if you are someone who demands the most from your braking system, the factory brakes leave room for improvement.
Read more here: "Big Brake kits and "Mr. Brembo"
6-piston Front:
365mm retail $̶4̶3̶5̶0̶ now only: $3995
380mm retail $̶4̶5̶9̶5̶ now only: $4150
4-piston Rear:
345mm $̶3̶6̶9̶5̶ now only: $3295
380mm $̶3̶7̶9̶5̶ now only: $3395
Brembo GT Big Brake Kit Includes:
  • 6 Front piston and 4 Rear piston Monoblock Calipers
  • Available in 355mm or 380mm configurations
  • Includes color choices of red, yellow, black or silver calipers
  • Vented Two Piece Slotted or Cross Drilled Brake Rotors with available Zinc Coating
  • Brembo High Performance Brake Pads
  • Brembo High Performance DOT Approved Brake Lines DOT/TUV approved
  • Mounting Brackets for your Specific application
  • Brembo two piece “floating” hat and rotor assemblies reduce unsprung and rotating weight and dissipate heat faster
  • Brembo “floating” anti-rattle disc hardware
  • Brembo billet caliper mounting brackets
IN STOCK - Order today!
Call: 1-888-635-7049
Email: sales@raceprecisionmotorsport.com
or
Will Call/Pickup available at our facility in Van Nuys, California. Installation services also available!
Brembo Brake Sytems are designed and tested specifically for endurance race use. For drivers who demand the utmost performance from their cars, these kits offer superlative performance for both normal driving and demanding track day sessions for useable braking torque.
      10-13-2014, 01:35 PM   #2
16
Drives: F80 M3
TTT!
Tags
bbk, big brake kit, brakepads, brembo, calipers
