      03-15-2011, 01:54 PM   #1
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Code 2D07?
anyone know what this is? I had a look at the sanp on tool just now at the shop and it said 2d07 throttle valve....any help?
      03-15-2011, 02:13 PM   #2
babydevilj
Drives: e46 M3. Z4 3.0i
http://www.peakeresearch.com/manuals...201.0%20NA.pdf
hope it helps
      03-15-2011, 02:27 PM   #3
Z4-VILLA
Afghanistan
111
thanks youre like one of the only people who respond nowadays....
      03-15-2011, 03:47 PM   #4
babydevilj
yeah theres not much help around here. and none of the other forums have too many members with z4s. luckily i can relate my m3 problems to this z4 if that makes sense. lol.
      03-16-2011, 04:45 PM   #5
Z4-VILLA
Afghanistan
111
ok great now i have code p1417!
wtf is this?
problem after problem....this all started immediately after filling up...gad damn it.....
      03-16-2011, 05:00 PM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
guess more and more people aren't amused by your attitude anymore
you're too impatient, and think people here owe you immediate help and information
      03-16-2011, 05:04 PM   #7
Z4-VILLA
Afghanistan
111
oh well...
thanks for the help though...
      03-16-2011, 05:07 PM   #8
Z4-VILLA
Afghanistan
111
I usually never pass up a person let alone a post that needs help, Youre the only person whose said this to me thus far, soooo either Im a pampered post member or your having a bad day cuz youre in Jersey and Jay Wow hasnt been calling you anymore....jking....seriously what gives....can I get help, or words of encouragement in the right direction?
      03-16-2011, 05:09 PM   #9
ZStig
279
I'm in the Philadelphia suburbs, not NJ. Anyway, your codes are probably from the headers
      03-16-2011, 05:13 PM   #10
Z4-VILLA
Afghanistan
111
damn, and damn lol i guess i had a longer day....any how I havent installed the euro's yet the whole thing is stock, my parts are all laid out on the kitchen floor
      03-16-2011, 05:14 PM   #11
Z4-VILLA
Afghanistan
111
this all happened right after filling up on gas and gunning it in that exact order....could i have put 83 instead of 93?
      03-16-2011, 05:20 PM   #12
Z4-VILLA
Afghanistan
111
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P1417.2. Fuel System 1 Status - Open Loop.3. Fuel System 2 Status - Open Loop.4. Calculated LOAD Value - 0.00 %.5. Engine Coolant Temp - 59.00 °F.6. Short Term Fuel Trim - Bank 1 - 0.00 %.7. Long Term Fuel Trim - Bank 1 - 3.13 %.8. Short Term Fuel Trim - Bank 2 - 0.00 %.9. Long Term Fuel Trim - Bank 2 - 0.78 %.10. Engine RPM - 0.00 Rpm.11. Vehicle Speed Sensor - 0.00 Mph.12. Ignition Timing Advance #1 Cylinder - 6.00 °.13. Intake Air Temperature - 59.00 °F.14. Air Flow Rate Mass Air Flow Sensor - 0.00 Lb/Min.15. Absolute Throttle Position - 8.24 %.16. Commanded Secondary Air Status - Atmosphere / Off. Monitor Information: 1. MIL - ON.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Not Complete.8. Secondary Air System Monitor - Complete.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Not Supported.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
this was the read out i got....i copied pasted from my email
      03-16-2011, 05:20 PM   #13
Z4-VILLA
Afghanistan
111
I hope some one has some widom for me...im gonna keep searching
      03-16-2011, 05:36 PM   #14
Jbs
The Photographer
Jbs's Avatar
Drives: 07 Z4MC BSM/Black extended
Where did you fill up??
Could it have been an additive etc? Do you have software for your chip?
John Batte Photography / Flickr / Facebook
2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob
      03-16-2011, 06:56 PM   #15
fr8tdog
International Bar Hopper
fr8tdog's Avatar
25
Drives: 2006 Imola Red Z4 M Roadster
I know this sounds like a dumb question! But did you tighten the fuel cap all the way? Did you check fuel filter and pump? The fact that this happened after fueling up leads me to believe it's either fuel cap or bad gas.
Edit: forget the gas cap...that was a dumb question
2006 Imola Red Z4 M, ESS VT2-500 Supercharged, SS V2 step headers, AEM water/meth, Nitto NT555R Drag Radials, ESS VT3 coming
      03-16-2011, 07:15 PM   #16
Z4-VILLA
Afghanistan
111
funny thing when i went to fill gas today I wasnt sure if the wetness around the cap was from gas or water of course my dumbass smelled my glove after i opened the cap so there was no way to tell, control and variable completely obsolete, also my dumbass does not know where the fuel filter is....I will look....
if I manage to fix this with just a tightening of the cap and a filter change i will politely ask that anyone within my area on this post come to my residence at their earliest possible convenience and chivalrously bitch slap me with a napkin and or glove, not in any particular order. ( preferably with an M embroidery, thank you)
      03-16-2011, 07:22 PM   #17
fr8tdog
fr8tdog's Avatar
25
Hahahahah
      03-16-2011, 07:24 PM   #18
ZStig
279
I volunteer
      03-16-2011, 07:30 PM   #19
Z4-VILLA
Afghanistan
111
thank you Roffle but some I think you will make the mistake of actually wearing the glove and fore going chivalry ( again, not in that order)
      02-19-2023, 08:56 AM   #20
924845192@qq
Drives: BMW 335
[FONT="<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">漫画无 MS</font></font>"][/FONT]
hi,Have you solved it? I have the same problem.
