      02-14-2014, 09:51 PM   #1
604skyline
Drives: 2020 M2 CS
more wheel questions - front width (which is better)
hello all,
2008 m coupe;
going to have some wheels made directly from bbs motorsports.... was wondering everyones thoughts on front wheel width and offset?
so initially told bbs what I drove, was replied with 8.5inch wide front and 10inch wide rear, I wrote back and asked if a 9inch front was possible, and was quoted yes it was....
so my question to all of you is...is there a better choice? I would think there is absolutely zero performance benefit of going wider to the 9inch.....is this correct?
i know our stock staggered fitment is 1inch different front and rear(18x8 front and 18x9 rear) am I weird to think the 1.5inch difference is odd? or is this quite common?
what does everyone then think....8.5inch front or 9inch front? the 8.5 would be et32 the 9 would be et35.
      02-14-2014, 10:08 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Performance benefit for street? Not really. What are you trying to achieve and what is the application?
And, width is only part of the equation, the other part is offset. What are the offsets for the wheels you plan to use?
Have a look at this thread. It should answer quite a few questions, and has a link to an offset calculator.
If you still have questions, then fire away.
      02-14-2014, 10:13 PM   #3
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
Hi there!
I went with 9f/9.5r when I changed wheels. I wanted to run the 245/275 tire sizes and it works great! I agree with the "not putting to wide of tire on to not enough wheel" camp.
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      02-16-2014, 04:20 PM   #4
604skyline
Drives: 2020 M2 CS
thanks for the couple replies.
finnegan, not really trying to achieve anything per say;
i think bbs motorsports go with a "flush" setup per previous discussions;
i think i listed the specs they provided
they have now given me two front options;
18x8.5 et 32
18x9 et 35
which is the better option?
rear will be 18x10 regardless.
is a 1.5inch staggered difference odd? i know stock is only 1inch different...
do I run 235 front on the 8.5? even the 9 possibly...
and then a 265 or 275 on the rear?
tires are going to be michelin pilot supersport
**my main concern is figuring out what I go with....
bbs motorsports provided the specs based simply on me telling what I vehicle they are going on, I made no mention of what I wanted etc...
      02-18-2014, 12:49 PM   #5
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
18x8.5 and 18x10
235 front and 275 rear. rolling diameter should be close to exact on both sets
instagram: @ dubsesd
      02-18-2014, 01:05 PM   #6
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
^ +1 That is a common, and good looking setup. Not considering 19's then?
I'm running:
- 19x8.0 front offset ET 47 (12mm spacer) with 245/35's
- 19x9.5 rear offset ET 27 with 285/30's
[SIGPIC][/SIGPIC]
      02-19-2014, 09:42 AM   #7
604skyline
Drives: 2020 M2 CS
Originally Posted by dubsesd View Post
18x8.5 and 18x10
which aspect ratio on the tires? and thanks for the info.
      02-19-2014, 12:03 PM   #8
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
245-40/275-35 set or 235-40/265-35 set is closer size Front and Rear. I always run 245/275 to be closer to the OE size but still smaller.
235-45/265-40 set can be run as well but they're larger than OE sizing. Of course, it all depends on the tire you select as well.
What are you going to do with your e88 19" ?
      02-21-2014, 05:31 PM   #9
604skyline
Drives: 2020 M2 CS
so everyone is saying the 8.5front and 10rear is optimal?
i personally am having a hard time wrapping my head around the difference, for whatever reason, considering stock is 1" difference width between front and rear....I just figure 9inch front and 10inch rear would be better? but bbs motorsport themselves recommend the 8.5front
thanks for all the help everyone, wheels are getting ordered next week, should be here 1-2 weeks after that.
zed4mr what 19" e88? not me??
      02-22-2014, 06:31 AM   #10
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
40 and 35
