02-10-2011, 10:55 PM | #1 |
Rep 2,747
DIY APR Splitter install
DIY INTRO:
This is a five part DIY for Z4M APR splitter installation. PART IV IS OPTIONAL. Part IV adds strength, rigidity and adjustability that will be useful for track applications. Part IV may be overkill for street use. In part IV the lower engine cover is permanently altered. This is the only step that would prevent you from taking you car back to stock without buying any new parts. The lower engine cover price is $157.00 Part I: -Hardware list & photos -Tool list & photo -Bumper removal instructions from 2007 BMW TIS -Photo headlight washer line that need to be disabled Part II: -Splitter preparations -Attaching the splitter to the bumper cover. Part III: -Splitter support rod installation Part IV: -Option 2 install (This complicates things but adds rigidity and adjustability that is useful for track applications. May be overkill for street use) Part V: -Complete installation PART I Hardware: 1. (8) stainless 1/4 20 x 1 machine screws 2. (3) stainless 1/4 20 x 2.25 machine screws 3. (22) stainless 1/4x1 fender washers 4. (11) stainless 1/4 20 lock nuts 5. (3) 1/4 20 nuts (temporarily hold the bumper in place while marking hardware locations) 6. (3) 1/4x3/8x1 spacers 7. (6) 1/4x1/2 washers or 1/4x1/2x1/8 spacers 8. (2) 3/16x2 molly bolt style anchors 9. (2) stainless 10mm splitter support rods 10. (2) stainless 3/16x1 fender washers 11. (8) OEM plastic expanding rivets (BMW # 51118174185) 12. [option 2 install only, see part IV] (3) additional stainless 1/4 x 1 fender washers 13. [option 2 install only, see part IV] (2) additional stainless 10mm splitter support rods 14. [option 2 install only, see part IV] (2) additional stainless 3/16x1 fender washers Tools: Prep: 1. Goof Off (decal removal) 2. 50/50 spray 3. Meguiar’s NXT 2.0 tech wax 4. Meguiar’s Ultimate Detailer 5. 3” blue painters tape Human support: 1. Safety glasses 2. Nitrile gloves 3. Headlight 4. Caffeine Measurement: 1. 72” ruler 2. 48” adjustable drywall square 3. 12” square 4. 6” rafter square 5. Digital caliper 6. Magnetic protractor 7. Sharpies 8. 1.5” blue painters tape Wrenching: 1. 1/2 ratchet wrench (wheel removal) 2. 1/2 17mm deep 3. 1/2 2” extension 4. 1/2 Torque wrench (wheel installation) 5. 3/8 ratchet wrench 6. 3/8 T30 male (for engine bay bumper hardware) 7. 3/8 11mm standard 8. 3/8 2” extension 9. 1/4 ratchet wrench 10. 1/4 7mm standard 11. 1/4 8mm standard 12. 1/4 10mm standard 13. 1/4 11mm standard 14. 1/4 3” extension 15. 1/4 5” flexible extension 16. 8mm ratcheting combo wrench 17. 10mm ratcheting combo wrench 18. 11mm ratcheting combo wrench Power Drivers: 1. 1/2 18V drill driver 2. 3/8 12V drill driver 3. 3/8 12V compact driver 4. 3/8 12V right angle drill driver 5. Drill bit set Cutting: 1. Jig saw w/ fine blade (only for option 2 install. See part IV) 2. Mini hack saw 3. Exacto knife Miscellaneous: 1. Needle nose pliers 2. Screwdriver set 3. Zip ties 4. Blue thread locker Bumper
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-14-2011 at 02:29 PM.. |
02-10-2011, 10:55 PM | #2 |
Rep 2,747
PART II
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-12-2011 at 02:34 AM.. |
02-10-2011, 10:56 PM | #3 |
Rep 2,747
PART III
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-12-2011 at 02:39 AM.. |
02-10-2011, 10:57 PM | #4 |
Rep 2,747
PART IV
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-12-2011 at 02:44 AM.. |
02-10-2011, 10:57 PM | #5 |
Rep 2,747
PART V
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-12-2011 at 02:57 AM.. |
filtercoffee106.00 |
02-10-2011, 11:30 PM | #6 |
Engineer
212
Rep 2,122
Drives: M235I 2015, 335i 2011
Wow, that's a great DIY man.
Thank You for the help to the community! |
02-10-2011, 11:41 PM | #8 |
Rep 698
You da bomb. I <3's chris.
edit. Add the hardware list to the top too
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
02-11-2011, 01:38 PM | #10 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
02-11-2011, 01:54 PM | #11 |
SSGT USMC - '78 - '86
13
Rep 487
Drives: Z4 3.0si
Great write-up! Thanks for all of the details! Excellent work and documentation!
Thanks,
Bill 2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's |
02-11-2011, 02:38 PM | #12 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
If one were to ever remove the splitter in order to resell vehicle, how obvious will the holes be in the bumper? I can see using the bolts to fill the holes but can they be seen by the naked eye while looking at the car on a level plane? Mostly worried about the outer bolts on the outside front edge and the front leading edge of the fangs. This is my biggest worry if I ever remove the splitter. Don't want to kill resale value if I install.
02-11-2011, 03:10 PM | #13 |
///M-fanatic
193
Rep 3,885
Here's the hardware list that I compiled (excluding the two extra moly bolts that Chris personally used):
You can pretty much get whatever nuts, bolts, and washers you'd like, but I went with what Chris used, which I'm going to list off the top of my head as follows: - Ten 1/4-inch diameter by 1-inch length machine screws/bolts (with 20 pitch threading) for mounting of sides of bumper/splitter - Ten 1/4-inch diameter (with 20 pitch threading) lock nuts for locking the bolts in place - Twenty 1/4-inch diameter inner hole by 1-inch outter diameter washers; one washer on the bumper side and one on the splitter side - Three 1/4-inch diameter by 2-inch length machine screws/bolts (with 20 pitch threading) for the center mounts in between the fangs - Three 1/4-inch diameter by 1-inch length metal spacer to help keep a healthy distance between bumper bottom and splitter top - Three 1/4-inch diameter (with 20 pitch threading) lock nuts for locking bolts in place - Twelve 1/4-inch diameter inner hole by 1-inch outter diameter washers; one washer on bumper side and one on the splitter side. And one on each side of the metal spacers as well. This allowed me a total of 13 mounting locations excluding the two support rods which I don't particularly want to use. Will see how the splitter behaves prior to tracking it, and see if they're absolutely mandatory. |
02-11-2011, 03:11 PM | #14 | |
///M-fanatic
193
Rep 3,885
02-11-2011, 07:32 PM | #15 |
Rep 2,138
Drives: Me
Chris,
A question: How did you ensure that the middle of the splitter fit flat against the plastic undertray and not start to ride down the hump? Edit: disregard. Last edited by Shipkiller; 02-11-2011 at 09:16 PM.. |
02-11-2011, 09:41 PM | #16 |
Rep 1,603
Drives: Imola Red Z4MC
Excellent DIY Chris! Really appreciate how much time and effort you put into these kind of things.
It just occurred to me that I may as well just lift the cover off my car, remove my bumper and install my lip over the cold months so she is ready to go by spring... One thing though, I've never removed the front bumper off of our cars, is it hard, easy? Anything i should look out for or be careful about?
///M - Some Mods 'N Stuff
02-11-2011, 10:25 PM | #17 | |
///M-fanatic
193
Rep 3,885
02-11-2011, 11:00 PM | #19 | |
Rep 1,603
size of torx wrench needed?
02-12-2011, 02:52 AM | #20 | |
///M-fanatic
193
Rep 3,885
If it were up to me, I'd just buy all-new fender liner push-pin tabs because they're a pain to remove sometimes and it's quicker to just yank them out, possibly destroying them. The bumper removal DIY can be found here: http://www.zpost.com/forums/showthread.php?t=79994 The part that I'm referring to is step 1 in the DIY. These push-pin tabs are annoying. And so are the bumper's side mounts. Oh, and I forgot the few 8mm hex screws at the bottom which also serve to hold the bumper in place a bit. |
02-12-2011, 03:02 AM | #21 |
Rep 2,747
Now it's a Real DIY. Updated part one through five with complete hardware, tool, and instructions
02-12-2011, 09:26 AM | #22 | |||||||||
Rep 2,747
Hardware added (along with a ton of other info/photos) Quote:
I added a ton of info including the BMW TIS bumper removal instructions in part I Thank you, All done now Quote:
The DIY is complete now. Hardware, parts, & installation have all been updated. For the fender liners I ended up using a re-usable plastic fastener from BMW. I also had a hard time with the original plastic rivets Thanks again
