      10-25-2012, 03:35 PM   #1
Spedracer81
Drives: Z4MC
Double check wheel fitment???
I'm looking at a set of hamann 19" x 8.5 et38 wheels for my 08 Z4MC..will theses fit without any issues?..
Thanks...
      10-25-2012, 04:57 PM   #2
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
are they square? if so you'll need a spacer in back.
8.5 et38 is perfect for the front.
      10-25-2012, 05:22 PM   #3
Spedracer81
Drives: Z4MC
what size spacer? square?
      10-25-2012, 05:29 PM   #4
itdnwiwbp
Drives: 330iZHP
Square=same size front and back wheels/tires. Sorry, can't help with correct spacer size.
      10-25-2012, 09:18 PM   #5
v3.2mc
Not a New Member
v3.2mc's Avatar
read this thoroughly. you'll need this and this too.
these 3 links combined provide a very good insight into choosing a wheel and tire combination that works with the ///m cars. there is a LOT of info in there, and it can be overwhelming... but take the time to read it. no one here can choose the stance you want for you.
as for spacers: they will make a non-aggressive offset fit where an aggressive offset is supposed to be. the rear of the ///m starts with a 9.0 et30... going to a 8.5 et38 will cause the wheel to move in towards the center of the car. spacers correct for this movement. note that you will also need longer studs to make this change work, but only for the wheels installed with spacers. see the first link above for fitments using spacers as well as properly chosen offsets that do not require them.
      10-25-2012, 09:40 PM   #6
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
You will need a 25mm spacer for the rear. But that rim is too narrow for the back end. It's smaller than stock
instagram: @ dubsesd
      10-25-2012, 09:59 PM   #7
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
OEM CSL have ET 44 offset for the front. You might need 5mm spacer to prevent rubbing on the strut.
      10-25-2012, 11:34 PM   #8
The HACK
The HACK's Avatar
1821
The offset numbers are negative, meaning the smaller the number, the further away from the surface of the hub it moves. So the ET44 offset of the CSL is actually 6mm CLOSER to the strut than the ET38 of the Hamann OP is interested in.
The problem with the fitment is in the rear, where the OE offset is in the 26-30mm range, while the Hamann wheels are 38 for the entire set. To make the REARS work OP will need 10-15mm of spacers on the narrower 8.5" wheels.
      10-26-2012, 08:59 AM   #9
Spedracer81
Drives: Z4MC
I think I'm going to go a different direction..I really do not want to use spacers..thanks for all the input
