      10-09-2012, 07:56 PM   #1
Punko
Drives: 07 Z4 M Coupe
255/35/18 Fit?
Would a Michelin PS2 255/35/18 fit on our OEM wheel?
Recommended fit is 8.5 to 10 wheel. I believe our front wheels are only 8"
I currently have 245/40/18 which is the limit for 8" wide rim.
      10-09-2012, 08:06 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Front wheel is only 8". No, it won't fit. I'd recommend a 9.5" wheel or at least 9" for a tire that size. Why? See what my experience was recently with a 245/40 on a stock 8" wheel. Spark Notes version is that really wide tires at the absolute edge of what will fit (e.g. 245 on an 8" wheel) perform much worse than a narrower tire on the same size wheel.
You can fit those size tires on wider wheel, and then it's going to require the right offset (probably about ET38 - ET35) and considerable negative camber to get it to tuck in under the fenders.
Better question is why do you want all that rubber? Look? Performance? (I thought the 245s looked a bit overstuffed on stock wheels myself--subjective of course.)
      10-09-2012, 08:42 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
IMO 235 fr / 265 rr is the best fitment on OE wheels
      10-09-2012, 10:08 PM   #4
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
I'm thinking of getting new tires and I was planning on on getting 235/40 Front and 265/40 for the back.... any thoughts ???
or should I stay with 225 and 255 and get spacers for a flush/cleaner look on stock wells?
      10-09-2012, 10:26 PM   #5
3002 tii
3002 tii's Avatar
2282
IMO 235 fr / 255 rr is the best fitment on OE wheels
But the heights are then mismatched...
Curious why you'd go with a 40 profile on a 265.
Follow for latest mods
      10-09-2012, 10:36 PM   #6
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
No particular reason, I don't understand why the front tires are a bit taller than the ones in the back.
I also like the way 40 look in the back.... looks like the prefect fit on stock suspension... IMO.
What do you recommend.
      10-09-2012, 11:20 PM   #7
Finnegan
Finnegan's Avatar
235/40 and 265/35. Keeps ratio front/rear pretty much same as stock. Smaller overall diameter, bit more effective wheel torque (about 2.5%). That comes at the expense of a smoother ride though (less rubber cushion).
Also, square stiffer sidewall tires--if going 235/265--work better with this 10mm wider size on stock wheels IMO than more rounded softer sidewalls. (Square e.g. Star Spec, RS3, NT05.)
      10-09-2012, 11:33 PM   #8
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
I personally run 235/45 and 265/40. It matched overall diameter on OEM versus 235/40 and 265/35
      10-09-2012, 11:34 PM   #9
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
The OE fronts (45% of 225mm = 101.25mm) are actually a bit shorter than the OE rears (40% of 255mm = 102mm).
If you like the look of the 255/40, then I'm pretty sure you would hate the taller look of the 265/40.
      10-09-2012, 11:36 PM   #10
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
I'm liking this 235/45 and 265/40 combo as well. Do you know of any website that will let me look up what tires (brand/type) are available in that combo? I usually can find a tire in one of the size, but then can't find a matching pair for the other size.
      10-09-2012, 11:37 PM   #11
Kgolf31
Kgolf31's Avatar
459
I just used Tirerack and go to the spec page and it lists all the details of each size.
      10-09-2012, 11:39 PM   #12
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for the tips
      10-10-2012, 06:13 AM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
oops... brain cramp. ....fixed, meant 265
      10-10-2012, 05:02 PM   #14
Punko
245/40 and 265/40 has been my choice because they were M3 OEM size....lots were available.....$ was good.
I asked the question because there were a set 255/30 for sale.
Lots of great info, thanks for the posts.
