08-15-2007, 11:17 AM | #45 |
Rep 1,379
Drives: E89 Z4 sDrive28i M Performance
08-15-2007, 01:11 PM | #46 |
Rosie.....
61
Rep 1,104
hey MAX...thanks for joining us......
max= 3 Rm = 1/2 155 = 2 socal = ? Yal = 1 beer (eel river triple Xultation), a triple shot mocha, and a can of diet dr. pepper. Ward = 3 beers and 2 vodka/soda socal you gotta come and play with us. Rozie
08-15-2007, 02:12 PM | #48 |
Rep 1,379
On top of the 3 beers and 2 vodka shots??? (I love port, good choice)
08-15-2007, 02:36 PM | #50 |
Rep 118
08-15-2007, 03:44 PM | #51 |
Rosie.....
61
Rep 1,104
now we're really learning about you guys........
08-15-2007, 03:46 PM | #52 |
Rep 15
Nitro tires
I have raced for many years and use various gases in my tires basically to keep the air(gas) from expanding when it heats up... in limited horse power applications (go karts) this is critical because the tire grows in circumference as the gas expands... meaning less torque out of the turns... none of this means diddly squat if you are driving on the road with modern radial tires... don't waste your money.
08-15-2007, 03:47 PM | #53 |
Rosie.....
61
Rep 1,104
can't believe this got moved to the technical talk thread.......guess someone's not paying attention to the ACTUAL topic discussed.
Rozie
08-15-2007, 04:39 PM | #55 | |
Rep 6,158
we go from useful info to crazy stuff on average by the 8th post see the "sport button" thread for another example! |
08-15-2007, 05:18 PM | #56 |
Rep 1,379
08-15-2007, 05:40 PM | #57 |
Rosie.....
61
Rep 1,104
you're treating me just like everyone that knows me does...that's just not right.
now your scaring away the newbies.......thanks for your input J_bydesign...i think that's why we got off topic, no one but 155 thought we should change to nitrogen in the tires. Rozie
08-15-2007, 05:47 PM | #58 | |
Rep 1,379
I never thought we should switch to nitrogen, I simply provided a summary and a link to the information you asked for. My dear friend Rozie, I do believe you have been drinking again. Your posts are becoming incoherent! |
08-15-2007, 10:55 PM | #59 | |
Rosie.....
61
Rep 1,104
Rozie
08-16-2007, 08:00 AM | #60 |
Rep 15
scared
scared...
scared is letting my 65 year old father take my Z4 across Alligator with my son... my father has lived in China for more than a year and has not driven in that time... not that he was a bad driver... back when he lived here... Thank you for the welcome... first time caller second Bimmer owner... first was an '07 330 i sedan... but my wife decided the Z4 was more Floridian... J.
08-17-2007, 09:32 AM | #61 | |
Rosie.....
61
Rep 1,104
12-22-2007, 10:59 PM | #62 |
Rep 3
okay so the debate over nitrogen is a loosing debate the simple fact of things is that the air is majority nitrogen, valve stems wear, temperatures change causing the seals to contract and change size loosing air pressure, really in the end you are wasting your money to have to check your air pressure 1 less time per month.
12-23-2007, 01:02 PM | #63 |
lettuce
18
Rep 201
nitrous oxide in the lungs may induce euphoria as it is an anesthetic and an analgesic.
not vehicle grade nitrous though cause it has H2S whose toxicity is similar to that of hydrogen cyanide. as people use to say, do not abuse nitrous oxide. Just enjoy it when you go to the dentist. |
12-23-2007, 03:32 PM | #64 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Nitrogen isn't affected by temperature changes like the 'regular' atmospheric mix. If you run your car on the track where tire pressures are critical for maximizing performance, then nitrogen is the way to go. If you are a daily driver kind of guy, then it makes no sense to use nitrogen unless you get it for free. Another benefit of nitrogen is that the larger molecules are less likely to seep out of your tire over time, thereby retaining a constant pressure over time better than that of a typical earth atmosphere mix.
You have to be 100% behind someone before you can stab them in the back.
David Brent |
