11-09-2009, 09:16 AM | #1 |
Rep 2
best setup for 19" without rubbing
Hi every one i am new to this forum
I need help to choice a right offset and tyre setup for 19" wheel without rubbing the fender. currently the car is on 18x8.5 et35 225/40/18 all round without any issue but i want to upgrade it to this 19x8.5 et38 front 235/35/19 19x9.5 et43 rear 265/30/19 will this work? my main worry is the car already lowered with kw v2 coilover. Thank you for your time Roy. |
11-09-2009, 12:28 PM | #3 |
Rep 374
should be ok depending how low you are. i have the same setup except 40mm in front and 45 in the rear. not a big difference at all. i dont rub and im lowered on eibachs
11-29-2009, 10:35 PM | #4 |
Rep 973
people usually put 235/35/19 and 265/30/19 so i didnt know you could put bigger tires, pros and cons? i am about to buy a set but you made me wonder because where i live the road is in really bad shape so i could use bigger tires for protection
tires are for a set of m6 replicas ive just bought 19x8.5 front offset 35 and 19x9.5 rear offset 40
if you want perfection buy a mercedes, or marry an accountant
11-30-2009, 06:20 PM | #5 |
John 14:6
59
Rep 588
I had 275/30/19s in the rear, on 35 offset wheels, lowered on eibachs/konis, and I noticed that the passenger rear tire rubbed on occasion.
I would recommend 265/30s. GL.
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
