      01-21-2014, 10:10 PM   #1
Gladius
Two Wheels or Four?
Gladius's Avatar
Drives: '18 Perf Edition m240i
Proper M Coupe offsets for ARC-8s?
Thinking about the ARC-8s, initially I was told 18x8.5 ET38 front and 18x9.5 ET35 rear, and that I could run up to a 12mm spacer in the rear, but have also been told to go et 22 in the rear. Is this effectively the same thing and would avoid the spacer? Is the et22 less concave?
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      01-22-2014, 05:53 AM   #2
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
Et22 are more concave than et35
      01-22-2014, 07:15 AM   #3
David70
When I was trying to decide the same thing I found this helpful -
http://www.zpost.com/forums/showthread.php?t=768791
      01-26-2014, 08:44 AM   #4
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
I'm running 18x9.5 +35 front and 18x10 +25 rear with my ec7's 245 front and 265 rear Dunlop z2's and I am pretty low, and no issue fitting
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      01-28-2014, 08:11 PM   #5
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Go with the 9.5ET22 rear. I have the 9.5ET35 with 12mm spacer because the ET22 wasn't available back then.
      01-28-2014, 08:28 PM   #6
Expert@ApexWheels
Expert@ApexWheels's Avatar
3511
Drives: M3
The direct fitment on the Z4M would be the 18x8.5" ET38 and 18x9.5" ET22 ARC-8's. Both the 18x9.5" ET35 and the 18x9.5" ET22 have the same concave face, but the 18x9.5" ET22 fitment would allow you to have a spacer free rear fitment that is more flush to the fenders.
