      11-04-2013, 06:51 PM   #1
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
Space available M coupe for offset changes
In order to allow use of all the offset calculators for any size wheels (17,18,19") the original offsets are F - 8" ET 42 and R - 9" ET 30. so I would really like to know how much space actually is available inside and outside front and rear so there is no rubbing with stock suspension.
May sound weird and I suppose I could go and measure the car but I am sure someone has done it more accurately than I
It would be great to know how many MM you can go in and out without rubbing - even with 10 mm clearance which is a little more than 1/4" so you can do the calculations.
Thanks to Anyone
      11-04-2013, 07:16 PM   #2
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Not to sound too simplistic here but I think the easiest is to kind of say what the "max" (subjective, I know) sizing we can run is, and from there one could scale back if need be.
To help, I think most Z4M guys run 18s. Some 19s, but it's similar either way.
For an 18" setup, the "near-absolute-max" size one can run in the front is 18x9.5 +35 on a 245/40 or a 255/35. This also depends on a camber setup, but that greatly increases one's ability to stuff something a little bigger (ie. a 10" wheel or a 275/35 tire) in the front fender. Expect rubbing and to have to do fender mods. The reason I say +35 is because even a 9.5" +38 wheel will contact the strut, I think.
In the rear, the generally accepted "max size" would be 18x10.5 +22 on a 275/35/18. One can go bigger, but expect to have to raise the car slightly, run a stiffer rear shock/spring combo, roll the fender, camber arms, etc etc. At 10.5" wide and +22 offset, we are getting close to the inside max width as well. I don't expect an 11" +20 to fit without rubbing the inner fender liner thingy... lol.
Anyone else care to chime in?
      11-04-2013, 07:22 PM   #3
drbvac
drbvac's Avatar
Thanks
[QUOTE=nekky;14924733]Not to sound too simplistic here but I think the easiest is to kind of say what the "max" (subjective, I know) sizing we can run is, and from there one could scale back if need be.
SO if I wanted to run 8.5" in front and 10" in the rear what range would be the best offsets cause its the same for 18" or 19"??
I think F ET36 +- 5 and R ET 20+-5 ?? OR larger >?
      11-05-2013, 09:16 AM   #4
Westersund
Westersund's Avatar
Sweden
478
Drives: BMW
This is what I am going with. Existing = OEM dimensions, New = New.
Front: http://www.willtheyfit.com/index.php...et2=38#content
Rear: http://www.willtheyfit.com/index.php...et2=32#content
Fronts shouldn't be a problem, But I don't know about the inner clearance in the back. Might have to go with 5 mm spacers there. Also I haven't decided if I'm going with the OEM tire height (45 and 40) or go down 5 mm (40 and 35).
      11-05-2013, 10:44 AM   #5
nekky
Wagon life
nekky's Avatar
8.5" in front is nice and conservative and I would run a 245/35/19 on a +30 or so for nice, proper fitment (no rubbing anywhere I bet and still more flush than stock). In the rear, +20 is just fine. +25 is ideal on a 10" wheel. It's what my CCWs are. They are 18" though, but this should give you a good idea. Use a 275/30/19 instead of a 35 aspect ratio. The car will naturally sit slightly higher on a 19" wheel, so I find it's a good idea to run a slightly skinnier tire so you can still go nice and low Not that I'm there yet. Much work still to be done and too busy with real life to do it just yet.
This is a 10.5" +22 on a 275/35/18 in the rear and a 9.5" +35 on a 265/35/18 in the front. The front is at approx. 3* of camber. It was drivable.
      11-05-2013, 03:21 PM   #6
drbvac
drbvac's Avatar
Wheels
I was going with this.
Front
http://www.willtheyfit.com/index.php...et2=40#content
Rear
http://www.willtheyfit.com/index.php...et2=25#content
Fronts shouldn't be a problem, But I don't know about the inner clearance in the back. Might have to go with 5 mm spacers there. Also I haven't decided if I'm going with the OEM tire height (45 and 40) or go down 5 mm (40 and 35).[/QUOTE]
      11-05-2013, 03:25 PM   #7
kklin
Drives: BMW Z4 M Coupe
My M Coupe still has OE suspension. Front tire's rim protector rubbed on the strut when going to 265 tires on 9.5 wheels.
Details and pictures captured at kklin's Z4 M Coupe for SCCA BSP (road tire). You'll have to do the math for your setup. As I noted, the tire sidewall's profile mattered in my case.
Thanks to Anyone
      11-05-2013, 05:16 PM   #8
drbvac
drbvac's Avatar
SIZES THEN??
SO: Looking at the CSL replicas from VMR
Front - 19x8.5 ET40 245x40 - 19"
Rear 19x10 ET25 265x35 - 19"
WILL these fit with no rubbing - no suspension mods -
